-   -   930 Rear Trailing Arm Pick Points (http://forums.pelicanparts.com/porsche-911-technical-forum/1086028-930-rear-trailing-arm-pick-points.html)
tocobill 02-14-2021 07:59 AM
Im going to be fitting 930 arms on my rsr build. I have the new boxed pick points. Does anyone have the dimensions or jig needed to fit these? I dont want to wing it. Any advice is appreciated. Thanks.
http://forums.pelicanparts.com/uploa...1613321944.jpg
Tom '74 911 02-14-2021 09:18 AM
If you bought weld-in boxes, you might check with the vender to see if they have dimensions they could share.
I know these guys used to build and sell these: http://johnjamesracing.com
Here are some instructions I found on the Tarett website. No dimensions that I could see, but maybe helpful nonetheless... interesting that they have JJR's name on them.
http://forums.pelicanparts.com/uploa...1613326485.jpg
tocobill 02-14-2021 09:49 AM
Thanks. These are by the non adjustable type. Just a raised version that gets welded on to the factory one like pictured above.
