Lambda relay pinout?
I’m looking to wire up my wideband O2, and thought rather than running a new wire from the fuse panel, I might be able to use the now-abandoned lambda wiring for a switched wire. (My fueling was backdated to a C3.0 system)
Anyone have guidance on what each wire on that relay does? No luck via search. Thanks Mike |
Anyone??
What year wire diagram are you looking for ? I can find that with a bit of help about it.
Sent from my iPad using Tapatalk |
looking at an 83, red wire at 30 is battery and red and white at 86 should be switched current and 85 is brown/ground. Lambda relay under the passenger seat.
Thanks! |
It serves the Lambda controller along with the fuel pump relay. The Lambda controller serves the frequency valve. If you are not running late CIS, then there is nothing to disturb. Assuming your gauge will be in the dash, probably less routing to go to the fuse box or ignition switch with an inline fuse.
| All times are GMT -8. The time now is 11:56 AM. |
