That's a healthy engine! Interesting that the compression is this high with 20/21 cams..[/QUOTE]
20/21 cams have no overlap they're designed for cis/dme emission engines Overlap is what give you low compression readings |
Thought there was 7 degrees of overlap with 20/21s? I got basically the same compression numbers with the same cam on an SC
Oh wow. That’s very good to know! Sent from my iPhone |
Overlap is what give you low compression readings[/QUOTE] ________________________________ The card that came with the 20/21s when they were acquired 20+ years ago... http://forums.pelicanparts.com/uploa...1614179246.jpg The current specs from Webcam's site, note the differences... http://forums.pelicanparts.com/uploa...1614179319.jpg I was concerned that my compression test numbers were low, until I remembered the 20/21s. Sal Carceller provided me with this calculator to try and estimate a percentage of what a 3.2 motor with 20/21s would compression test out to vs stock. Wallace Racing: Dynamic Compression Ratio Calculator |
The card that came with the 20/21s when they were acquired 20+ years ago... http://forums.pelicanparts.com/uploa...1614179246.jpg The current specs from Webcam's site, note the differences... http://forums.pelicanparts.com/uploa...1614179319.jpg I was concerned that my compression test numbers were low, until I remembered the 20/21s. Sal Carceller provided me with this calculator to try and estimate a percentage of what a 3.2 motor with 20/21s would compression test out to vs stock. Wallace Racing: Dynamic Compression Ratio Calculator[/QUOTE] Famoroso- great, relevant info, thanks!! My lack of cam knowledge is kicking in here; how does the 20/21 cam compare to the 594/595? |
594/595 is a lot more aggressive
I see RSR thrown around a lot, "real RSR" 3.0 pistons have a matching smaller CC head, the pistons I have look like the RSR wedge dome head pistons, but were NIB 10.5:1 CR for stock heads. Some claimed RSR pistons are just high CR with a regular dome. I was pooping puppies till I did the maths and found out that my pistons were indeed made for stock head chambers. http://www.914world.com/bbs2/uploads...1404912280.jpg |
Here is Mahle “RSR” 3.0 built on a SC case, with 935 heads @ 85cc and dome volume of 40.3cc: 10.6:1. http://forums.pelicanparts.com/uploa...1614270496.jpg
Here is a Mahle “RSR” 3.4, built on a Carrera case with 935 heads @ 84.6cc. Dome volume is 37.5cc: 11.2:1. http://forums.pelicanparts.com/uploa...1614270832.jpg
You cannot use those valve events in any calculator as they are taken @ .05 of lift
There is an additional 20deg of valve duration. Intake opens somewhere around 16 to 18 BTDC and closes around 60 to 62deg ABDC. Depending on what timing number you used Ideally, you would need to take actual measurements at the valve with .006" lash Quote:
I'd be more interested in whether or not it had new head studs installed during the rebuild. That #5 leak could very well be from a popped stud.
And where was the compression test performed? You're going to get different readings in LA than you will in Denver. |
These are mine.
http://forums.pelicanparts.com/uploa...1069134036.jpg According to my notes, the dome was 39.3cc, an my heads are 90 cc. Andial advertised them as 98mm RSR. |
As already pointed out, you need the true seat to seat duration events and no cam specs give this. We need to know exactly when the intake valve closes and hits the seat. Likely around 60-65 ABDC.
I think the compression numbers are a bit low even for that cam. I'd say you should be around 130PSI or so. Just do a leak down to get the rest of the story. The leak down does not care about the cam. The later the intake closes the lower the compression number will be. |
| All times are GMT -8. The time now is 08:05 AM. |
