-   -   Where is the resistor pack? (http://forums.pelicanparts.com/porsche-911-technical-forum/1087012-where-resistor-pack.html)
M5guy 02-25-2021 12:38 PM
My footwell fans have stopped working. The fans are good, just not getting 12v. Relay and fuse are good.
(It’s a 930 so there is not a fan/relay/fuse in the engine compartment.
Thanks.
john walker's workshop 02-25-2021 03:40 PM
I think it's in the front trunk, right side, under the dash. Late 80s turbos had like 3 micro-switches in the auto-heat unit. Had to troubleshoot one once, total pain.
M5guy 02-25-2021 04:08 PM
Thanks John. I guess you have to take the seats out to get to the automatic heater control unit, correct?
I know it’s kind of working because I can hear the solenoid moving the baffle cables. BTW, the heater control is $1600 new from Pelican.
motorracer 02-25-2021 05:55 PM
Heat
This is the micro switch that was bad on mine sounds like it is the same problem i had.sorry can't upload pictures
motorracer 02-25-2021 07:02 PM
Micro
http://forums.pelicanparts.com/uploa...1614308480.jpg
M5guy 02-26-2021 07:10 AM
Thanks, I may pull the seats and check those two switches. Or maybe I’ll just figure out a way to retrograde to the two little handles and a hi/lo fan switch. ;)
