Brake booster - where to grease / service?
I removed the master cylinder and brake booster from my 1979 after diagnosing a failing master cylinder.
The booster has some brake fluid damage on the outside. Fortunately, the inside looks very good. The fluid did not appear to make it inside at all. There's some red tacky grease on the pedal end of the booster. Where should new grease be applied, if any? Is there anything else to service on it while it is out? I will clean and grease all the pivots on the linkage. |
I just replaced my master cylinder and like you, would like to know if I should do anything to the booster before reinstall.
