Classic Retrofit Electrocooler Temp. Probes
Can someone clarify where the temperature probe for the evaporator goes? The only reference I find in the manual is "you should have already installed this by now" in the section on installing the air handler.
Old 03-28-2021, 03:06 PM
MikeD930's Avatar
I placed the temp probe by using short piece of fuel line (don't remember diameter) made for small engine (i.e. chain saw, lawn mower, dirt bike, etc) over the probe and drilled hole in blower/evaporator box then placed the probe through it. Just need to make sure the drilled hole is slightly smaller than probe with fuel line tube. See photo below is what I did on mine (ignore unattached cable...I was not done installing the kit).
MikeD '87 930
Old 03-28-2021, 04:21 PM
Thanks,
I inserted the probe through a hole on the other side, based upon your picture, it looks like I'm OK.
Old 03-28-2021, 05:28 PM
