901/11 transmission/clutch problem
Hi All,
I'm at the end of a five year restoration of a 911T. With the warmer weather coming up here in Sweden I was looking forward to start up and break in of my restored engine.
When adjusting the clutch wire I notice I've got problems engaging the gear or clutch. If I get it into any gear I would not be able to turn the wheels, right?
Nothing is finally set as everything has been apart so maybe the clutch is not properly adjusted? I have set it to 20 mm free play at the pedal and made sure the cable housing runs in the guide bracket the proper way.
Where do I start looking? If the clutch wire is not adjusted properly the clutch should be engaged at all times right? I have slackened the wire as well but can still turn the wheels (when transmission is in gear).
I have just put the engine in but not filled it up with oil yet. I would try to avoid taking the engine out again. I have a really small garage...
I'm positive I have the right clutch, pressure plate and clutch release bearing.
What can I do to find the problem?
Appreciate all your help!
Jörgen Forssling
Gothenburg
SWEDEN
Old 02-28-2021, 04:42 AM
When i turn one wheel, the other turns. Should i have one of the wheels on the ground to make any assumptions? I'm getting a boroscope the upcoming week and thought about looking into the drive shaft/clutch when turning.
How should a proper setup look? When in gear the drive shaft should turn I assume. When not in gear it should not. And do I have to lock up one of the wheels or doesn't that matter?
//Jörgen
Old 02-28-2021, 06:28 AM
You need to block one wheel with an open diff, as you guessed.
Old 02-28-2021, 09:02 AM
Thanks for your input. I guess the easiest way would be to put it on the ground (now on dollys) and see if I can move it when in gear, in neutral and with the clutch depressed.
//Jörgen
Old 02-28-2021, 09:06 AM
the clutch disc could be frozen to the flywheel? If i'm reading the question correctly
ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 02-28-2021, 03:32 PM
Non LSD the wheels will spin in counter directions if trans is in gear
Ian
Old 02-28-2021, 03:34 PM
