Kind of Blue
MrBonus's Avatar
Does your state have emissions for older cars - any tips passing w/ hot rod?
Hi all,
I've been away for too long, attempting to fall in love with a Lotus, but realizing my heart is with air-cooled Porsches.
I have my eye on a particular hot rod, a '71 with a transplanted/rebuilt 2.7 dual Weber setup. My state handles inspection at the DMV and we are required to pass emissions testing once, even if I plan to register it historic, which amounts to a idle sniffer test.
Now, there is a safe harbor that can grant you an exemption, but that usually involves paying a qualified shop up to $1000 to "fix" your emissions issues and I'd rather not go down that route.
Anyway, the engine runs extremely well but have limited experience or knowledge with any tuning tricks or additives to ensure I can get through inspection (just once!). The car may pass on its own accord but before I "pull the trigger" on the purchase, this is the last piece that's concerning me, and an item that I cannot glean from a mere inspection/drive.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 02-11-2021, 08:33 AM
Been here a while
look closely, typically, the car just has to meet 1971 standards. You should be fine.
looking for 1972 911t motor XR584, S/N 6121622
Old 02-11-2021, 08:39 AM
Kind of Blue
MrBonus's Avatar
You are correct. I passed with a '71 Ghia with a 1.9 previously, but by the skin of my teeth!
https://regulations.delaware.gov/AdminCode/title7/1000/1100/1126.shtml
The requirements are here (If I copy/paste, they'll format terribly).
Old 02-11-2021, 08:40 AM
Driver
Noah930's Avatar
You have no idea where the car stands now (in terms of emissions), it sounds. If you could go to a garage and have them hook the car up to a gas analyzer, that may help soothe your concerns a lot, if it's well within whatever 1971 limits you have to pass.
But in general, before a smog test, I try to run a bottle of Techron through the week or so before. I try to change the oil. And I make sure to get the engine nice and hot (not just warmed up) for the test, itself. California's test is done on a rolling dyno, so I also make sure the tires are properly aired up. My car is otherwise stock though, so I don't fool around with adjusting the CIS or spark or anything like that. Obviously in your intended hot rod, YMMV.
1990 Black 964 C2 Targa
Old 02-11-2021, 08:59 AM
Kind of Blue
MrBonus's Avatar
You are correct. I have done no emissions testing whatsoever. The car runs, for lack of a better expression, like a "raped ape." This makes me want to believe it will likely be just fine since there is no indication it's running lean, rich, or poorly in general.
I was thinking of throwing some Techron in there as added protection and good tip on getting it nice and hot. Of course, it's snow season up here (4" on the ground this morning) so I'm likely not getting it to a shop any time soon and need to get moving on either buying or passing on the deal on the table. Fortunately, we do not test on a dyno; they simply throw a sniffer in the tail pipe and let it idle for about 30 seconds.
I'm probably going to just buy it anyway, and if I need to solicit some friends in the automotive industry to provide me with the appropriate safe harbor documentation to satisfy the DMV, I will, but I'd rather avoid calling in those kinds of favors.
Old 02-11-2021, 09:12 AM
creaturecat's Avatar
ask for someone that knows how to drive a standard.
i had to drag a youngster out of my 915 equipped 911, once upon a time .....
Old 02-11-2021, 09:47 AM
the old three on the tree pickup truck? they would have to grab an old guy from out back. jeez.
Old 02-11-2021, 09:48 AM
Kind of Blue
MrBonus's Avatar
Haha, you don't get out of the car here fortunately.
Old 02-11-2021, 09:49 AM
RETIRED
Joe Bob's Avatar
Ask the seller to provide a pass from the smog weenies.
2012 ML350 3.0 Turbo Diesel
Old 02-11-2021, 11:14 AM
Kind of Blue
MrBonus's Avatar
Buying out of a state that doesn't have such concerns. I think it's absurd my state still does curb idle tests on true classics, but not much I can do other than move.
Old 02-11-2021, 11:23 AM
targa72e's Avatar
It depends on the state. In CO cars older than certain age do not need emissions. CA has rolling year limit i believe. Since the car in question is a 71 if it is a T it would have come with carbs. The 2.7 engine should look the same so visual would be easy to pass. E and S would be MFI and if person inspecting could tell the difference could fail on visual. If the car is in good running order then it will probably pass the instrumented test as the limits on older cars are quite high. You should be able to find specific information for your area requirements on line. I know several people who register their cars in counties in CO that do not have emissions requirements as a alternative option.
john
Old 02-11-2021, 12:46 PM
Kind of Blue
MrBonus's Avatar
john
Thanks, John. Visual inspection is not relevant in this state. It's strictly by the emissions numbers at idle (linked above). The only thing they inspect is for cats, if relevant to your vehicle year. Obviously, a non-concern for me.
Old 02-11-2021, 12:58 PM
Kind of Blue
MrBonus's Avatar
Also, anyone want a Lotus? Runs really well until it doesn't!
(It runs well now. Right now. Today.)
Old 02-11-2021, 01:20 PM
can't go wrong finding a shop with a sniffer (PPI shop?) and having them "optimize" the mixture for passing before you go in -- the settings for it to easily pass emissions aren't necessarily the same as those that promote it running like a "raped ape"
Old 02-11-2021, 01:30 PM
Clause 4.1.2 Register it as an antique. I have 3 of mine registered as antiques and I never have an issue when I get inspected. We have no pipes in VT though. If they did me Race Car would never pass.
AlfasRule!
72 Montreal (Da Pumpkin)
75 Alfetta Sedan, 75 Alfetta Coupe Race Car
82 Spider, 84 GTV-6. 84 GTV-6 Verde (GiGi)
87 Milano ( Da Winta Beata)
Old 02-11-2021, 03:09 PM
Kind of Blue
MrBonus's Avatar
The car passed emissions with flying colors and they failed me for yellow H4 headlights.
Old 03-04-2021, 02:36 AM
We do not have emissions at all in Washington state
Jeremy Brooks AKA VWLOOSENUTS
***My cars are built to meet my approval, not yours!! My money, my cars, my happiness.
Old 03-04-2021, 07:30 AM
did they fail you because they were yellow or h4 or both?
Old 03-04-2021, 07:44 AM
Kind of Blue
MrBonus's Avatar
Strictly due to the color. I have to swap lenses or housings and head back.
Old 03-04-2021, 08:59 AM
RETIRED
Joe Bob's Avatar
I use yellow tint. Get popped peel it off.
Old 03-04-2021, 09:47 AM
