txhokie4life's Avatar
Magic trick to bleed the slave cylinder on 996 Turbo
In the midst of replacing shave cylinder.
Got it out and back in... time to add fluid, bleed and test.
I can’t figure out how to crack the bleed valve on top of the slave cylinder
I’ve got no room. Wrench doesn’t fit up there and while I can get a crowsfoot in it
I can get a ratchet on itehats the trick to
Bleeding the slave cylinder on 996 Turbo?
Frustrating as there are many difficult steps I have overcome to get stuck here.
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 03-07-2021, 08:42 PM
https://www.youtube.com/watch?v=tfaRQ60iUI8
Bleeding starts about 23 minutes in.
Old 03-08-2021, 08:20 AM
spedrcr's Avatar
If it's anything like bleeding a slave on a G50 then you may need to "make" your own tool. And use a pressure bleeder...
Old 03-08-2021, 10:05 AM
I use a old oil squirt can and back bleed.
Old 03-08-2021, 01:43 PM
Gravity bleeding should work on any hydraulic circuit as long as the reservoir is higher than the bleed screw and the fluid path is open, yes? If you're impatient, you can tap your foot. Instead, crack the bleeder screw and allow air to escape until you see a steady flow of fluid. To see the air bubbles in 3D, attach a hose to the bleed valve, then close.
Using a pressure bleeder is like prepping for a colonoscopy instead of eating green veggies. YMMV.
Sherwood
Old 03-08-2021, 02:30 PM
The issue I had was I couldn’t get anything I had on the bleed screw.
But then I found a stubby 11mm and that worked.
My brake bleed 11mm had an offset that hit the tranny tunnel and my crows foot wasn’t working either.
I had all the other bleed equipment.
Have to be test driven... but I think she’s good to go.
2001 996 GT2
Old 03-08-2021, 06:48 PM
