-   -   PSA: Check your brake lights. (and then get stuck trying to replace the switches) (http://forums.pelicanparts.com/porsche-911-technical-forum/1088453-psa-check-your-brake-lights-then-get-stuck-trying-replace-switches.html)
sugarwood 03-14-2021 01:20 PM
My brake lights don't go on unless I use excessive pedal pressure.
I only realized this because someone informed me at an intersection.
This might be a good thing to verify on your car as it may not be flagged at your annual inspection.
If you replace the 2 brake light switches,
make sure you order the right 2 or 3 prong switch.
I began this repair today.
First remove the carpet, cover plate, cross bar, and detach 2 air hoses to access the 2 switches.
Unfortunately, both of my switches have clearance issues.
The front switch has a brake line that crosses right in front of it.
I found an image online that does not look like my brake line routing.
I suspect my brake line may have been replaced at some point, and not routed correctly around the switch.
There is no way to get an 22mm offset wrench or 22mm socket onto the switch.
Can't get an opened ended wrench in there either.
Will probably take it to the shop and report back how they approach it.
Maybe they'll need to detach that brake line.
I wonder how much play, if any, that would create.
The other end is attached to a rubber hose, that can be detached from the bracket, resulting in possible play.
I will post an update when I get this resolved,
In the meantime, I advise others to do a quick check of their brake lights!
https://rennlist.com/forums/attachme...ont-switch.jpg
https://i.imgur.com/jEAitv6.jpg
manbridge 74 03-14-2021 04:30 PM
Done a lot of these over the years on both 911 and 930. While clearance is tight I don’t recall any major disassembly to replace.
david.avrahami@ 03-15-2021 06:43 AM
brake lights switches
2 switches from my 87 Carrera are for sale today...reason? I changed them with new ones but found out afterwords that a burnt fuse was the problem....
See my 87 Carrera for sale listing.
GH85Carrera 03-15-2021 06:54 AM
One of the checks I do every so often is hit the brake pedal while in the garage to see just how hard the brake pedal has to be pressed for the lights to come on. It is scary to be out and about while driving and realize the brake light only come on in hard stops.
I have a offset box end wrench to R&R the switches. I bought it just for that purpose.
http://forums.pelicanparts.com/uploa...1615816380.jpg
I just bought the one, and not an entire set, but a wrench like this is great to get the switches off and on.
garment 03-15-2021 07:47 AM
sub'd - I have replacement switches on my workbench now...
darrin 03-15-2021 07:52 AM
David -- this happened to me years ago, traced the blown fuse to a failing cruise control module -- hit cruise control level (even accidentally) and brake light fuse would blow - FWIW
manbridge 74 03-15-2021 09:26 AM
Flex head ratchet wrench works well.
thsupernge 03-15-2021 09:41 AM
This is great guys, thanks for posting!
I literally just discussed this project this morning! This is a critical safety issue and needs to be addressed. My brake lights only come on if I am standing on the pedal-NOT GOOD!
I used to do these all day on bugs and the like but the access is not easy on the 911.
Are you tefloning the threads...etc.?
Any help, tips, tools, advice-pics etc are HUGELY appreciated!
You guys are awesome!
manbridge 74 03-15-2021 10:05 AM
Teflon is for house plumbing, no need here.
sugarwood 03-15-2021 10:39 AM
The best tool appears to be a deep offset wrench 22mm.
Before your order, verify if you have 2 or 3 prong switch.
My case is unique because the brakes lines have benn replaced and not bent correctly. I will need to detach and move the brake lines, and then bleed the lines.
thsupernge 03-15-2021 11:46 AM
Cool, I was thinking maybe a crow's foot might be able to get in there too. Any recommendations on sensors (2 prong)? I have been told just to buy the german made units or the corresponding vw models because they last much longer.
sugarwood 03-15-2021 02:27 PM
Crowfoot
7/8" is 22mm
I got the ATE brand since I read that cheapo brands may leak.
Since the R&R is a hassle, I'd rather only do it once.
Satanas 03-15-2021 03:25 PM
Or you can install an electric switch.
This way, your brake lights come on as soon as you stroke the brake pedal
(Use google translate)
https://pcxsubxci2xux76xb2ippjepji-adwhj77lcyoafdy-www-type911-org.translate.goog/blog/?idblog=10919
thsupernge 03-15-2021 03:34 PM
Oui je vois. Merci beaucoup! Était-ce difficile?
Marc Bixen 03-15-2021 04:51 PM
Basic rule of thumb, and there may be a couple of exceptions, 3-wire >83, SC, 84>3.2's are 2-wire.
sugarwood 03-16-2021 08:46 AM
There is overlap
3 prong. 1977-1986.
2 prong. 1984-1989.
911obgyn 03-16-2021 10:11 AM
Mechanical switch for mehttp://forums.pelicanparts.com/uploa...1615914669.png
emac 03-16-2021 06:01 PM
Originally Posted by 911obgyn (Post 11261745)
I did the mechanical switch works great but I have this issue. 81sc with three prong switches. As soon as I press the brake pedal I get Instant brake lights but my parking brake light turns on and will not go off.
Suggestions—ideas?
Ernie
Satanas 03-17-2021 12:32 PM
Not difficult, see electrical connection:
https://pcxsubxci2xux76xb2ippjepji-adwhj77lcyoafdy-www-type911-org.translate.goog/blog/?idblog=10915
dan88911 03-17-2021 12:33 PM
+1 more, I add something like this to my brake lights a few yrs. ago
http://forums.pelicanparts.com/porsche-911-technical-forum/773628-mechanical-brake-light-switch-modification-78-sc.html
