Plugs fouling quickly
I have a 70 911 with a stock 2.2 and an MSD Street Fire. I recently had it serviced by a reputable Porsche mechanic and the engine is in good health. My problem is spark plugs fouling on every trip out, I don't do short trips, mixture could be a bit rich but not enough to cause fouling every trip. Has anyone used hotter plugs or iridium plugs with a similar set up? I didn't check what plug or heat range I have in before writing this which doesn't help but some suggestions would be helpful. Thanks
yes it would be nice to see ,what do you have in your 911
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
It's a 914 ...
For starters, what plugs are you using?
It's running NGK BP7 E S
Fouled plugs were a constant issue back in the day. The solution was simple. Keep the revs up.
Richard 87 Targa 20 LS 500 |
Maybe BP6ES or Denso Iridium IW16 would help. Any idea what your jetting is?
If you have webers I use 55 idles and just replaced my plugs with Champion N11YC which I think are just a little hotter. This in my 72 with an 83 twin plug 3.0L.
You can control plug fouling with hotter plugs , give it a try it's a cheap fix, but it's telling you that you are possibly running rich.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
