1972 911T Fuel Line
I'm almost done replacing all of my fuel lines. Do I have to drop the transmission cross mount to get to the back tunnel lines? I have the old ones off but for the life of me can't get the new ones back on. Ugh
Old 03-14-2021, 04:31 PM
Harpo's Avatar
I dropped mine to get easier access
Old 03-15-2021, 06:29 AM
Flojo's Avatar
another good reason for you to drop the engine…
usually you pull the old attached to the new in one go
will be tough now...
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-15-2021, 06:53 AM
BoxsterGT's Avatar
Porsche Crest
You can do this, but very helpful to support the Trans & drop the front Mount.
I think Flojo is referring to this...
It's my M14 Female Coupler used to pull the replacement Polyamide tunnel lines into the Tunnel.
However, you have a 72 with steel Tunnel Lines, and this is another procedure entirely.
I can help if needed, just email me.
Len.Cummings at verizon.net
Old 03-22-2021, 03:29 AM
