-   -   Ride height Chart (http://forums.pelicanparts.com/porsche-911-technical-forum/1089271-ride-height-chart.html)
Jonny042 03-24-2021 06:37 AM
Ride height Chart
Does anyone know the original source of this chart, and where I might find a higher res version of it? I get a headache every time I try to read it!!
http://forums.pelicanparts.com/uploa...1616596633.jpg
TIA!!!
carrera30 03-24-2021 10:19 AM
I have a performance chart ~ the same res.
Sent from my SM-A115A using Tapatalk
Bill Verburg 03-24-2021 10:56 AM
TIA!!!
Since I posted it I suppose I can tell you where it's from
911 Workshop Manual - printing # W313e
also in
Porsche Vehicles for Sport Purposes - printing # W351e
911pcars 03-24-2021 11:28 AM
I applied some PShop to it.
http://forums.pelicanparts.com/uploa...1616614066.jpg
Still legible?
Sherwood
Jonny042 03-24-2021 01:33 PM
Still legible?
Sherwood
Better, and thanks!! But I asked a friend to apply his talent and he basically re-drew a layer on top of the old. I have to get a better file from him but here's a preview. Ignore the typo (there's only one that I see)!
Special thanks to Cory for doing this!!! I'm going to print it poster size for the shop. EDIT - Wow it looks great!!!!
EDIT - removed.....
Jonny042 03-24-2021 01:35 PM
Also a special thanks to Todd who sent me a nice high res copy of the "Sports Purposes" manual which I did not have. Good reading!!!
Brookieslayer 03-24-2021 05:44 PM
Ride
Perfect timing for a reprint!
Will come in handy very soon!
MBAtarga 03-24-2021 06:29 PM
typos?
WC - Wheel Center
TC - Torsion bar Center
TCC - Torsion bar Cover Center
911pcars 03-24-2021 08:08 PM
Ok. I'll ask. Can someone explain how ride height is derived from this chart?
I got a headache even at the new size.
Sherwood
Jonny042 03-25-2021 04:48 AM
Sherwood
If you are trying to derive fender height (which is a terrible way to accurately measure/compare ride heights, too many variables), you can't.
But it's a good way to see where you're REALLY at compared to the factory ride height. Which is 108 front, 12 (above) rear, measured as indicated on the diagram.
Jonny042 03-25-2021 06:50 AM
Final
Here we go, a final version....
http://forums.pelicanparts.com/uploa...1616683712.jpg
Bill Verburg 03-25-2021 07:21 AM
Sherwood
The 3 columns on the left are,
front height___rear height___how much lower the car is from stock
all measured by the factory method in mm
note that the rear heights are pos. until the car is lowered 12mm from stock, from there down the #s are neg, alternatively use the absolute values and then think, is the WC above or below the TC?
http://forums.pelicanparts.com/uploa...1616685354.jpg
I added the factory method info and corrected the WC, TC, TCC notes
Jonny042 03-25-2021 07:47 AM
Thanks, Bill!
While you were working I think we made some changes as well (including a few of yours). I'll get the full res version updated and post the final results again. Sooner or later it'll be 101% correct!!!
PorterF 03-30-2021 07:42 AM
I would like a copy, could you please forward or post a link?
Thank you!
Jonny042 03-31-2021 04:39 AM
PM sent!
Jay Laifman 09-09-2025 11:02 AM
Interesting chart. It shows that for every ride height the front TC is 120 mm lower than the rear TCC. Is that a golden rule? My car was recently redone and I have a 131 mm difference. So the front is possibly 11 mm too low? Or could there be a reason a shop would want a bigger drop? This is a 1973 911 with factory S front spoiler.
Bill Verburg 09-09-2025 01:21 PM
no, back then when the chart was first put together the importance of aero wasn't as well documented as it is now. Since then for aero the chassis wants a bit of down in front stance so Δb(torsion bars heights somewhat higher are pretty std these days. But it's also up to the owners taste.
For most street use aero just isn't that significant.
