Turn Signals Not working - Hazards Do
Hi everyone!
Long time reader, first time poster. Ive scanned what feels like hundreds of topics regarding similar issues but never found someone who has a working hazard switch and lights, but turn signals that don't work. Im really not sure what is causing the issue. Verified all fuses are fine Replaced the Turn Signal relay Checked numerous times that the wiring into the light switch are correct and all accounted for. Im really at a loss to why my turn signals have stopped working all of a sudden. Anyone have any suggestions to what is causing this? Thanks in advance |
did you check under the dash if the combo switch in fully plugged in??There are 3 connection there.
Another thing..when you replaced the turn signal relay ,have you replaced it with 3 prong relay or 4 prong relay? Ivan |
I had something similar and reseated all the wires going into the four way switch. One or two were loose.
| All times are GMT -8. The time now is 04:01 PM. |
