Armin
1974 Radio Ignition Noise
I have a 74 911 2.7L. I get considerable ignition interference with the Blaupunkt Frankfurt radio, which has been verified to work. New center dash speaker is installed.
Did model year 74 come with the radio suppressor condensor part# 91161890300
I see a couple on Ebay for sale.
Old 03-29-2021, 07:30 PM
Registered Minimalist
75 911s's Avatar
Yep, my 75 has one. Is your Faraday cage still intact? That is to say, are the ground wires still attached to the rear metal decklid? Was a plastic decklid put in place? Do you have the grounded ignition wires?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 03-29-2021, 07:44 PM
yes, but not from the factory... at least not an the majority of the 74s. There were two styles I believe. There is a technical document on this and most were installed by dealers. Mine was mounted on the coil bracket on a 74.
Old 03-29-2021, 08:40 PM
Armin
I'll check on this. I definitely don't have a plastic decklid .
Gotcha, any idea where I can find the technical bulletin or document?
Planning on buying the 75+ radio suppressor and gonna try to make it work.
Old 03-30-2021, 05:35 AM
Armin
Ground wires are still attached to the metal decklid.
Here’s what it looks like:
Old 03-30-2021, 06:01 AM
Number 7 is a "Radio Noise Suppressor".
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 03-30-2021, 06:22 AM
Not to break balls but you're still using a radio?
Old 03-31-2021, 05:22 AM
75 911s's Avatar
Both suppressors are visible in your picture. Ensure they are connected to the voltage regulator back there. Looks like they are. Perhaps the power on the radio was tapped into the wrong lead under the dash.
Old 03-31-2021, 07:00 AM
Armin
We have gone through quite a bit of work to get everything looking and working as it did originally back in 74. I found the original 73 BP Frankfurt radio and I'm picky. Why have something if it doesn't work well? Same goes for my seatbelt sensors, windshield wiper nozzles, etc... But I get it. I did sneak a bluetooth chip into the DIN slot on the back of the Frankfurt radio so at least I can stream
Old 03-31-2021, 10:53 AM
Armin
Hmmm could be. There was a previous Pioneer headunit in there. I'll try to check it out.
Armin
Old 03-31-2021, 10:54 AM
https://www.amazon.com/Isolator-Suppressor-Amplifier-Equalizer-Subwoofer/dp/B07S8VKG99/ref=sr_1_1_sspa?dchild=1&keywords=Car+Radio+Power+filter&qid=1617223805&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzOTNXNkJGWEJFMUFJJ mVuY3J5cHRlZElkPUEwMjAzMTEwMzg1SFY2TTcwOEozVSZlbmN yeXB0ZWRBZElkPUEwMDMzODk1UVlVR0kwWVpMVk1QJndpZGdld E5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm9 0TG9nQ2xpY2s9dHJ1ZQ==
Get one of these.
AlfasRule!
72 Montreal (Da Pumpkin)
75 Alfetta Sedan, 75 Alfetta Coupe Race Car
82 Spider, 84 GTV-6. 84 GTV-6 Verde (GiGi)
87 Milano ( Da Winta Beata)
Old 03-31-2021, 01:51 PM
E Sully's Avatar
I don't know if it was used on 1974, but along with the regulator capacitors this radio noise suppressor was installed on my 1973. In post 4 it was used in place of part#3, RPM sensor, that was no longer needed. https://www.ebay.com/itm/Porsche-911-Distributor-Condenser-nos-new-old-stock-radio-suppress-91161890300-/373018598227
Ed
1973.5 T
Old 04-01-2021, 05:04 AM
Armin
Oddly enough, I purchased this same exact condenser from this Ebay user 2 weeks ago, and received a random Magnetti Marelli condensator for a Fiat 125! I've sent the return back and bought another one from a different seller, and will try to install as soon as it arrives.
Old 04-01-2021, 08:48 AM
