Opinions/thoughts on front shock inserts
I have to replace the inserts on my 88, they are totally shot and it's holding the car back from what should be a quality Porsche ride. I have the units marked BOGE on the outside (orange/red in color) and I have read that I can replace them with Koni and others.
I like the Koni
https://www.pelicanparts.com/More_Info/KON86411039SPORT.htm?pn=KON-8641-1039SPORT&SVSVSI=0819&DID=197435
because of the adjustability. It would be nice to keep it medium for most uses and firm for the canyons etc. I have had good luck with them in the past.
For background this is for normal (spirited) driving, not the track. I currently have Stien's on the rear that are fairly new but might match with appropriate Koni.
Thoughts, comments, experience and snide remarks on Koni, adjustable, application etc., or should I go another way altogether?
Old 04-02-2021, 05:00 PM
Does no one have these or have some comments/suggestions?
Old 04-08-2021, 03:35 PM
Red Line Service
Marc Bixen's Avatar
It's a nice shock, but you have to match the rears. Problem with Koni's is that to adjust the rears, you have to unbolt the bottom bolt, compress them completely to engage the adjuster,adjust it, then bolt the lower back in. Not quite like turning the knob on the front.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 04-08-2021, 06:19 PM
Porsche Addict
Personally, I would keep the same brand all around the car.
Lawrence - 1986 911 Carrera Coupe Grand Prix White
1959 Land Rover Series II
1962 Volkswagen Sedan Ragtop
1959 Porsche 356A Coupe
1971 Porsche 911T coupe
Old 04-08-2021, 06:23 PM
Antomero's Avatar
Just ordered M474 ClubSport inserts for my Boge struts. Special order from Germany ����
Old 04-08-2021, 06:39 PM
Bilstein HD all around. You won't regret it.
206 637 4071
Old 04-08-2021, 07:01 PM
Antomero's Avatar
I was told Bilstein HD are not valved correctly for stock torsion bar especially for early Carreras.
To stiff !
Old 04-09-2021, 07:56 AM
Really good point, I had not considered that.
Old 04-09-2021, 08:28 AM
