Heat exchanger air temp?
The heat exchanger going from engine to the cabin, how hot does that get? I need to know for buying tubing. Thanks
Old 04-05-2021, 09:12 AM
bump
Old 04-05-2021, 12:29 PM
If you’re talking about the tubing from the heat exchangers to the heater tubes along the rockers, most use SCEET tubing. Aircraft Spruce is a well known supplier.
Old 04-05-2021, 12:44 PM
Yeah that's the one. I have a tubing i would like to use, yet the rating is only 300 deg. Would it be ok?
Old 04-05-2021, 01:16 PM
