Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
correct fuel filter for my 1978 SC
all,
looking to replace my fuel filter on my SC that currently has the Bosch part 045090016 on the filter.
i havent been able to find that part but found Bosch 0450905021 but noticed that the fuel direction is opposite that of my fuel filter. Can i run the fuel in the opposite direction? is there another filter i should be using?
any help appreciated!
thanks,
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 06-08-2021, 05:55 PM
Racer
winders's Avatar
93011007602
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 06-08-2021, 06:24 PM
Fuel Filter Fittings.......
Originally Posted by Kemo View Post
all,
thanks,
Kemo,
Your fuel filter -016 has 14.0 mm x 1.5 (Inlet) and 14.0 mm x 1.5 (Outlet), identical inlet and outlet. So if you are going to use -021 filter which has 14.0 mm x 1.5 (Inlet) and 12.0 mm x 1.5 (Outlet), you will need a 12.0 mm x 1.5 adaptor.
0-450-905-003............14/14 (inlet/outlet).
0-450-905-016............14/14 (inlet/outlet).
0-450-905-021............14/12 (inlet/outlet).
0-405-905-079............14/12 (inlet/outlet).
Tony
Old 06-08-2021, 08:11 PM
HarryD's Avatar
Kemo:
Make you you have the flow as shown on the filter body.
I save the fittings from the old filters to allow me to make sure I have the correct sizes. They do not go bad and at most, you need to replace the crush washer.
Often, you can swap them around.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-08-2021, 10:53 PM
Bill Douglas's Avatar
I remember from years ago my SC's fitting were different to what the online spec's said they should be.
Before I place my order I think I'll actually remove mine and see what I've actually got.
Old 06-09-2021, 12:20 AM
pete3799's Avatar
93011019600 fit my 79sc. Had to remove the two fittings from the old filter and install on the new one.
Pete
79 911SC RoW
Old 06-09-2021, 03:56 AM
