Best tire & size choice for 1977 911
I need to replace my Yokohama's on my '77 coupe. Looking for opinions on replacements. Please let me know your favorite brand and tire size.
Thanks.
Old 04-07-2021, 12:15 PM
My 76 couupe has 205/60/15s on worn Dunlops all the way around..same issue for me..please help us!
Old 04-07-2021, 12:22 PM
I’d go ahead and put on a Nomex suit before other replies start rolling in.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 04-07-2021, 12:28 PM
Porsche Addict
You might want to post your wheel sizes?
Lawrence - Euro '78 911 SC Targa Fern Green
US '86 911 Carrera Coupe Grand Prix White
Old 04-07-2021, 02:58 PM
'77 tires
My wheel size is 15"
I was running 205x60x15 Yokohama's. Then I found out one rubbed just a little on the passenger rear against a braided oil line.
Old 04-07-2021, 03:16 PM
I just bought four Vredestein Sportrac 5 195/65 R 15 from Tirerack at a very good price - the size is similar as the 185/70 that was the original fitment
Old 04-07-2021, 05:30 PM
French member
Aurel's Avatar
I run 205/55/16 in the front, 225/55/16 in the back. I like the kuhmos ectsa PS31. I used the ectsa Supra before but they don’t make it anymore. Inexpensive and good tires. I really like the lower profile 55 tires on 16 inch wheels, but it may not work as well with 15 inch wheels.
Aurelien
'78 SC Targa, DC15 cams, backdated heat and exhaust, AC delete, Turbo tie rods
New rings on Alusils...I did it!
Hear my rebuilt motor! Dyno
Old 04-07-2021, 06:02 PM
I like my 195/65/15 Goodyear Sport Eagles it's a tossable V rated tire that is solid and not too expensive.
Old 04-07-2021, 07:21 PM
HarryD's Avatar
I like my Continental ExtremeContact Sports. Use them for everyday, HPDE and rain tire for Autocross (in place of my Hoosiers).
Harry
1973.5 911T Targa - "Smokey"
2003 BMW Z4 3.0i
2009 MB C300
Old 04-07-2021, 09:40 PM
Bill Verburg's Avatar
Most '77s would have come w/ 4 x 6x15ET36 wheels and 185/70 x15 tires
If you are going for originality Pirelli CN36 in that size are the tire to use
later in the product cycle life 195/65 x15 were supplied in those wheels
all of the above tires are ~25+" tall
for a biy of a performance boost 205/55 or for more of a boost 205/50 can be used on the 6s, I'd avoid 20/60 as that is even taller than oe is is a drag on performance
There must be a custom oil cooler setup on that car for the 205s to rub, w/ 205 the backspace is around ~5.5" and most 911s even w/ stock oil lines can get away w/ ~6"
Bill Verburg
Old 04-08-2021, 07:20 AM
Have a look at the Yokohama Advan Fleva which looks like a replacement for the S-Drive which I am running on my 77 coupe. Loved my S-Drives.
Old 04-08-2021, 01:49 PM
HarryD's Avatar
I am using Continental ExtremeContact Sports 205/55-16 on my 1973 with 6x16 Fuchs. There were no rubbing issues after I upgraded to Turbo Torsion bars. Prior to that I had a rub about 1-2 inches above the fender.
When I use my 205/50-15 Hoosier SM's on my 6x15 Cookies, I had a rubbing issue where the tire shoulder would rub against one of the nuts on my right spring plate. This was resolved by installing a jam nut in place of the stock nut, cutting off the exposed threads and adding a 5 mm spacer.
Harry
2003 BMW Z4 3.0i
2009 MB C300
Old 04-08-2021, 01:56 PM
Interesting
I've seen 215/60 on 7x15ET23.3 rub a couple of inches up into the paint in back, the back space in that combo is ~ 5.5" too. Same as 6ET36 w/ 205/55, Hoosiers do run wide in the 205 size by ~.4" over other brands
Generally contact on the inner side at the il line and a trailing arm bolts occurs at b/s ~6"
Here's a tire w/ 6" of back space
Bill Verburg
Old 04-08-2021, 02:51 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
