Ignition Switch Bolts
Getting ready to replace the contacts on my ignition switch.
The two hex head screws make me think the switch has been replaced before. The other two look like the backside of a pop rivet, and one has a nut threaded down over it. Do these get drilled out, or? Is there any downside to replacing all the fasteners with standard socket head screws?
Drill them out. Only downside to replace with bolts is easier access for criminals.
Brew Master
Nick |
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I replaced mine with torx security bolts
Harpo ..as i have mentioned these will do nada...if anybody wants to do some harm they will just use slide hammer and pull the tumbler so any rivets or anything else will be still there but the ignition worthless
Ivan look, this is how it works.....the thief broke the slide hammer tip https://www.youtube.com/watch?v=Qzrr7r7UQdw
My only question about the protective covers, is how the heck do you get them off again? The ones I've used had a breakoff bolt to lock it in place.
If you mean the 911-Lockshield John?..it is hard and that is exactly the point....i only tell clients in private.It is a PITA but doable....
Ivan
Brew Master
You shameless self promoter Ivan!
Nick |
Nick not really,i do not like to push my stuff...i just want to help....not asking for money or any other selling tricks;-)
Here in Europe there is at least 2 per month stolen 911 or 930 ..just last week another one is gone... the strangest thing is..it is mainly Belgium or Holland 3rd is Germany as the least one 930 .... Ivan have to admit sold a lot in France and England;-)))
Can someone share what this connector is for?
(Purple and Black wires)
it activates the buzzer to alert you the key is in the ignition when you open the door
Awesome, thank you!!!!
