hydraulic clutch conversions
Greetings everyone. My wife has a 1982 911 SC Targa. she is a slight build person and has trouble with the pressure required to depress the clutch. If I cant fix this the car goes on the block. I have been looking at hydraulic conversions. Are these conversions to lighten the pressure required at the pedal or are there other reasons to go the hydraulic route?
Old 04-30-2021, 10:20 AM
Have you tried clutch helper spring?
http://www.pelicanparts.com/techarticles/911_clutch_cable/911_clutch_cable.htm
Old 04-30-2021, 10:52 AM
spring
Originally Posted by mtb001 View Post
This is called the Omega spring , It is standard on your 82 911.
The average clutch pressure is only about 20lbs .
Maybe her seat is too far back and she is releasing the clutch whit her leg instead
of he ankle ?
ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 04-30-2021, 01:36 PM
That makes sense to me. I'll be on the creeper this weekend to check it out.
Thanks!!
Old 04-30-2021, 02:11 PM
(man/dude)
Jonny042's Avatar
Possibility that the omega spring is missing or maladjusted. The clutch cable needs to be almost pretensioned and the omega spring needs to work in synch with the clutch pressure required.
I have a G50 with a hydraulic clutch and wouldn't say it's any lighter than either of my 915 equipped cars.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-30-2021, 04:16 PM
Old clutch assemblies can be stiff. The thinner the disc, the harder the pedal effort. Old cables get a drag when the internal sleeve in the sheath breaks and moves with the cable motion.
206 637 4071
Old 04-30-2021, 10:09 PM
Racer
winders's Avatar
I converted my 915 to a CMS hydraulic slave setup using the recommended master cylinder size and is just as hard to push as with the cable setup. Maybe even a bit harder.....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 04-30-2021, 10:25 PM
How much do you want for the car?
Old 05-01-2021, 06:14 AM
