alternator
need to replace alternator in my 71 911
number of reviews say this doesn't fit, https://www.pelicanparts.com/More_Info/AL9341X.htm?pn=AL-9341-X-INT&SVSVSI=5867&DID=13355 but is listed to fit is pelican wrong about this? |
You can opt to let rebuild yours
Is much cheaper I have a 911 1970 and viewing the picture it seems correct |
Find a lost rebuild shop. You will be better off. |
Check if the VR (voltage regulator) is built into the Alt or by the rear fuse box. Was separate on my 73 and integrated into the Alt on my 89.
Replaced mine a couple weeks ago. Remanufactured Bosch Alt from Advanced Auto. Fit and works perfectly. Prob better than the Velaro Alt that was stock. $200. Looks new. Chris |
All the alternators available now are Valeo types up to the 964 Bosch. Because the box indicates Bosch, doesn't mean that it's a Bosch design. |
Is much cheaper I have a 911 1970 and viewing the picture it seems correct http://forums.pelicanparts.com/uploa...1618522862.jpg http://forums.pelicanparts.com/uploa...1618522862.jpg |
going to try the rebuild route
thanks |
Dave,
It says Bosch right on the Alternator and it fits and works perfectly. Installed it a couple weeks ago on my 89 Carrera. No way would Advanced Auto put a Velaro alternator in a Bosch box or change labels. Chrishttp://forums.pelicanparts.com/uploa...1618592143.jpg |
Again, Bosch NEVER made an alternator for a 911 3.2 ('84-'89). That Valeo, "Bosch Rebuilt", is even less reliable than the original Valeo. Because instead of French Valeo regulator, it uses a junk China regulator. Look closely, it's a reman junk! |
We have sold over 40 of these Bosch remanufactured units in the last year with only 1 returned. Being its a remanned unit theres always an off chance of QC issues but this appears to be the correct unit for your model and year.
Auto Air Marine Electric in El Cajon can rebuild it. Talk to Scott
Some still believe the earth is flat and the sun revolves around it! |
Porsche also used a Valeo as an OEM alt (75A) in the '82/'83 911SC, not a Bosch. |
1971 911
I installed one of these high output alternators in my 88. With lots of modern add-ons to include upgraded A/C (Griffith's system), sterol, USB plug-ins, radar detectors, etc, my volts would run in the low 13s and dip into the high 12s when all the/ a/c fans and condenser electric fans would come on. After installing this alternator, I never see lower than the high 13s.
https://www.classicretrofit.com/collections/upgraded-alternators/products/porsche-911-high-output-150a-alternator Good luck. |
| All times are GMT -8. The time now is 08:43 PM. |
