Fuel line coupling - what is it & where to buy ?
Hi, please see attached picture this is the fuel return hose that connects to the fuel line that comes out of the tunnel behind the steering rack and connects to the fuel tank, be great to know what type of coupling it is and where to get a barbed version of it, my car is a 76 911 Coupe.
All parts diagrams that I have seen do not detail this part. Any help much appreciated. Cheers Mark
The part isn't detailed because Porsche made it part of the entire fuel line (which is listed).
However you can check the folks at with www.batinc.net or with Len (Pelican username "Boxster GT") - he fabs fuel lines but I believe he also sells couplings/adapters. HTH
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Chances are good that you can take that hose to a hydraulic hose shop and he'll cut off the hose ferrule, replace the rubber hose, then crimp on the new ferrules, saving your old fittings.
If you want, you can cut the ferrule off yourself (the fitting is barbed on the hose end), replace the hose, and reattach it with a couple of screw type hose clamps. Last edited by dannobee; 05-19-2019 at 04:36 AM.. |
I wouldn't reuse that fitting......send Len (Boxster GT) an e-mail.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Sorted thanks, looks like it's one of these:
M14 x 1.5 Metric Swivel Nut 90 Degree Fitting x 7mm - 8mm Hose Tail Cohline Bent 90 Degree Elbow tube x Hose Fitting with Conical nipple according to DIN 3863 & Swivel Metric Nut. Thanks to all Mark. |
I brought all of my old fuel lines to a local hydraulic shop, they removed the old fittings, cleaned and inspected them, then they crimped them all to new hoses. I spent a total of $35.
![]() I can help anyone who needs replacement Metric fittings....... ![]() For both Fuel and Oil, standard & custom..... ![]() I also offer my line of "Direct Connect" custom AN fittings that allow aftermarket components to be used directly without additional adapters for both Fuel...... ![]() ...and Oil.... ![]() Please email me for info. Len.Cummings at verizon.net
![]() Also, a word of caution when having "local hydraulic shops" make up your lines.... Many do NOT have the correct crimps to properly assemble new hose on your original Metric fittings. They are too long and crush the hose at the "bump" (shown in the first photo on post #7 above) where the fitting is meant to retain the hose. This results in premature failure of the hose...... ![]() ![]() The is what the proper crimp looks like.... ![]() The same goes for improperly crimped Oil Hose by "local hydraulic shops"...... ![]() ![]() I am happy to assist with any questions you may have. Len.Cummings at verizon.net
![]() Bump for update on info.... For those who may need standard or custom Metric fittings. Email is Len.Cummings at verizon.net
your stuff looks great...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Northern Motorhead
Good to see you're still helping out the community Len , aren't you retired ???
You made some custom fuel hoses and other bits for me a few years back when i swapped a 3.6 in my car. For anybody considering fuel line or other hose replacements, i highly recommend Len as his work is outstanding !
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
![]() Thank you for the kind words, Phil. I am enjoying my retirement and hopefully providing a small service to the Porsche community. It is a little thank you for the years of pleasure I have had with these wonderful cars. For the OP or anyone else, here is the M14 Female Coupler used to assist in pulling the replacement Polyamide Tunnel Lines into the chassis.... ![]() It is included free of charge with the Tunnel lines I offer. I do have extras if someone has another need. Please email me only, NO pm's. Len.Cummings at verizon.net
