74 iroc bumper driving lights
It looks that stock driving lights will not fit iroc ,rsr front bumper.
Any idea what will fit?
Old 04-20-2021, 02:21 AM
flat6pilot's Avatar
Do you mean the fog lights, or the turn signal/marker light combo?
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs
Old 04-20-2021, 09:43 AM
turn signal / marker.
Old 04-20-2021, 09:59 AM
If you haven't cut the enclosure off the bumper, you can mount the lens to the bumper to cover the enclosure, then drill a hole in the end of the enclosure to run the wires through. I did that , but my enclosures had been cut off, so I used ( user here ) Spoke's LED turn signals, which mount inside the lens, and I glued a sheet of foam rubber to the back of the lens to prevent water from getting in, and painted the back of it with PlastiDip to make sure it was water-resistant. I haven't tested the weather-proofing, but the lenses mounted OK after I JB-Welded some aluminum brackets onto the bumper.
Old 04-20-2021, 10:04 AM
flat6pilot's Avatar
Does your bumper have a cutout like the pic below? If so, it's only meant to have the turn signal/running light in there. No additional side marker light. Unhook and put on your shelf.
Old 04-20-2021, 10:08 AM
