cycling has-been
bkreigsr's Avatar
Seeking torque value, aftermarket sump plate
Does anyone know the torque value for the eight 10mm nuts on this aftermarket billet sump plate?
I've been using 71 in lbs - same as the valve covers.
Thanks, Bill K
Old 04-20-2021, 10:12 AM
flat6pilot's Avatar
I believe I used the same value. About 7ft-lbs. (Also an aftermarket billet plate) I'm using a rubber gasket so I carefully tightened until it was equally pushed out all the way around. (i.e. snug) No leaks so far.
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs
Old 04-20-2021, 10:27 AM
cycling has-been
bkreigsr's Avatar
Thanks Kyle. Good to know we're on the same page.
Bill K
Old 04-20-2021, 03:37 PM
