1976 911S 2.7 Megasquirt 1 with distributor-less coil pack?
Hi
I am in the UK and currently have a BITZEFI Megasquirt 1 controlling the fuel and a MSD AL6 firing blaster coils with a 123 Tune 6 distributor.
I believe the Megasquirt can be modified to control a Ford EDIS system. MS1 V2.2
If this is the case I would like to be able to remove the MSD and 123 to simplify the fuel and sparks? I assume the wasted spark won't be an issue being able to pick up a pair of cylinders on opposite combustion strokes at the same time?
Has anyone done this successfully?
Many thanks,
Old 04-23-2021, 02:35 AM
