one of gods prototypes
spent some time today installing my audio
![]() it goes like this....... head unit........blau toronto cd changer......blau 10 disc audio control eql carver spacial enhancer audio control line driver JL audio 550/5......100 watts for each 5-1/4"......25 watts for each tweeter.......250 watts for the single 10" door components are currently crossfire bmf's....they will be replaced by a quart 6.5/4/tweet setup within the month. sub is a crossfire bmf 10" which sits in a custom box made from the smugglers box. here are some pics....... head unit procesors under passenger seat subwoofer
Brought to you by Carl's Jr. |
That is f'ing trick! Do you have the dimensions for the sub box?
nice work, amir
Amir '83 911SC |
procesors mounted (easy access to the eq)
amp mounted against from wall on simple rack........i'm having something stronger made out of aluminum this week. it's loud enough to overpower my new loud exhaust.........still have lots of tuning to do, this gives me yet another reason to spend more time in the 911 ![]() later enjoy
Great
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
i don't have dimensions for the box......because the smugglers box is the box.....sorta......
there is a divider under where the top board splits (in the center just next to the sub), plus some sylicon(sp?lol)........ this sealed off the steering rack/ventalation things.....still able to service anything in there. under the sub i simply sealed up all openings to make it airtight......then i used chunks of wood to "eat up" airspace to get the volume to the subs specs........ the goal was minimum weight, amps in the nose for ballast, i only added about 20-25 lbs total.....but i DID lose alot more from the A/C removal
Brought to you by Carl's Jr. Last edited by bell; 05-03-2003 at 02:41 PM.. |
very cool. So I assume that the front components are bi amped from separate channels of the amp and the audio control unit is an active crossover? I had never though off doing that before, but it would work because the five channel amp has three inputs... hah. I like it.
So is the spatial enhancer unit basically time delay sort of thing? I've always though time delay would be tough to set up right and it would be easier just to modify the install instead of adding more processing. But then, I've never tried it...
the enhancer i have is just a "toy" which adds ambiance at 3 selected frequencies and also manipulates the phasing (works similar to the audio control esp-2).
the amp splits the signal to all 5 channels internally so i only have to feed it L/R channels. the amp is crossingover the front channels to bandpass for the mids, the rear channels are highpass for the tweets and the sub gets the lowpass. the controls on the amp allow for complete flexibility of operation and are adjustable down the the xover slope, it's a very trick piece ![]() time alignment is something different which requires a "phase shifter", but can be dialed in to control phasing over 360degrees between L/R. if i can't get my soundstage the way i want it i can add one to get it nailed......but with the control i have right now i doubt i'll need it
ron.....when i get the quarts installed this thing is going to be spooky......right now i definately have the power with deadly dampening and it's pretty killer, but i know my current speakers aren't going to last
![]() i'm going to spend a few hours driving/tuning tomorrow........ i needed to run 2 speaker leads into each door......what a PAIN.... being i do this for a living i'm glad i didn't have to pay labor charges......i don't think i would want to pay that bill......i can be expensive
Montana 911
damn...makes me want to trade in my 8 track! Ha Ha...very nice!
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
"..when i get the quarts installed this thing is going to be spooky."
--- well, if anybody knows 911 audio, you sure do " but i know my current speakers aren't going to last" ---try keeping db below 105, LOL "i needed to run 2 speaker leads into each door......what a PAIN...." --- now may be a good time to run wires for auto door locks, party hearty bell/Ron
![]() i did run a 4 strand into the door for when i decide to do the alarm (LEDS on the door lock caps ).
bump for the weekdayers
bell,
Quick ?.... You have the sub in the trunk?? How does it sound in the passenger compartment? Thanks!
86 Carrera Red/Black 80 SC Coupe Silver/Black (gone but not forgotten) |
Awesome job! Where did you mount your changer?
John 1997 993 2012 991 |
the sub up front sounds strong and punchy like it should
![]() the sub in the front is simply where EVERY sub in any car needs to be.....when you goto a concert where are you looking while listening? at the stage........which is in front of you ![]() sub-harmonic frequencies are non-dirrectional, but everything around it will resonate making it somewhat dirrectional. also with the sub in the front you can run your crossover higher for the sub which'll add midbass to your whole front stage and take some stress out of the demands of the door speakers. ![]() basically it sounds fantastic, i'm still playing with the internal volume of the box.....it's not quite where i want it yet. it does however make my toronto skip......which has never skipped....it's going out again this week to have the whole transport section replaced. the changer is currently in front of the amp, i'm running no spare right now (it's trashed....need a replacement) it'll be moved....just not sure where i want to put it yet.
Buy them, sell them
I have an NIB 8" sub (brand name, can't remember which...) at home. The smuggler's box is an ideal place for it! Thanks for the tip! I'll probably need another amplifier though...
1931 Oakland Eight Special Saloon 1985 BMW E28 525e (Euro 528e) 1989 911 Carrera Sport 3.2 G50 Cabriolet |
Awesome Bell, simply awesome!
the big bucks 911 audio group that advertises in Excellence use the sub in front.........Ron
Awesome job Bell! A quick question though. I've seen a few different variations of the sub in or over the smugglers box configuration, and I still can't figure it out. I experimented once by removing the smuggler's door, and mounting a board with a inverted 12" on top and it didn't sound right, like there was a speaker in the trunk. Of course I still had my AC. So I'm still trying to understand how your sub works. As I read in your installation, you fully enclosed and sealed the airspace below the sub within the smugglers box. So the sub fires into the trunk? How do the bass waves enter into the passenger compartment? By the resonance of all the stuff behind the dash?
