-   -   911 pertronix c/d problem 1977 (http://forums.pelicanparts.com/porsche-911-technical-forum/1091774-911-pertronix-c-d-problem-1977-a.html)
mmike 04-23-2021 08:09 AM
Can some one help me. When I turn over the engine it does not fire until I let the key go. I am sorry. The cdi unit is made by PERMATUNE .Thank you.
reclino 04-23-2021 01:56 PM
Check to see if voltage is sagging while your cranking. May need a new battery. Or ground wires need to be cleaned.
icarp 04-23-2021 06:05 PM
Save yourself some headache, Get rid of all things Pertronix . For 35 years I have been fighting them
Go back to points if you have to. Permatune is fine .
Look into the 123 distributors
Ian
spyerx 04-23-2021 06:09 PM
Pertronix work fine. Check your wiring... and you're sure the CDI is OK and your timing/pertronix setup is good?
icarp 04-23-2021 06:19 PM
45 years in the biz of vintage racing and there is nothing worse than Pertronix
Just my opinion
Every one that I have ever come across has failed
They even admit that average life is less than 4000 miles , and racing ? no warranty at all.
