123 distributor curve. Please look and comment!
Hi
Finally connected my usb 123 dizzy to the PC and the curve looks completely different and wrong compared to a normal 2.7 curve? Car is 1976 911s converted to megasquirt 1, MSD AL6, 123 distributor. Help!? Cheers http://forums.pelicanparts.com/uploa...1619200778.jpg |
It looks like you are at 20 degrees at idle (1000 rpm) and then take a long time to get from 22 to 28 degrees.
Have you verified using a timing light? |
It is wrong. Was it hard to start? At idle it should be closer to 10 degrees BTDC.
Yup at cold it requires a light throttle to maintain idle at 900rpm. By time it warms up the idle is nearer 1200rpm.
Also sounds flat and smells a bit! The dizzy cap and arm are burning out quickly. I plan to move curve 2 degrees at a time until I end up closer to stock graph and then request local dyno shop to fine tune |
All three devices are programmable for ignition curve. I would be very careful, there could be curves lurking in the Megasquirt and the MSD box
dizzy
SBL , said he changed the rotor SBL you should have a 1977 vw golf rotor in the 911 |
SBL, like Jonny said you might have ghost curves lurking. I think you should zero out the curves on the MSD and the MS and use the distributor. Set your curve as stock and then check with a timing light to verify.
| All times are GMT -8. The time now is 03:26 PM. |
