fuel in oil w/webers
My 2.4 911T has a Weber conversion. I've owned it for 6 years without this problem. It got enough gasoline in the oil to raise the level about 2 quarts. Any ideas? Stuck float?
Jeff Parker
72T *Sold*
98 Neon R/T sedan, red
98 Neon R/T coupe, white
98 Neon R/T coupe, blue
Old 05-04-2003, 08:03 PM
Stuck float, high fuel (float) level or excessive fuel pump pressure. Look down the carb throats during idle. There should be no fuel discharging into the passage. If so, fuel level is too high. Fix whatever is causing it, then use the PMO external float gauge to check the level. Change the oil too.
There's a remote chance the float pivot pin has backed off. However, this is pretty drastic as it allows the float ... to literally float. The engine will hardly run due to the volume of uncontrolled fuel.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 05-04-2003, 09:14 PM
Fix it quick, thinned oil can be bad in a hurry!!
Old 05-04-2003, 10:11 PM
needlevalve's Avatar
Not sure if this applies to Webers but I had the exact same problem with my 70's Zeaniths. In the bottom of each bowl there is a needlevalve which allows the flow of new gas into the bowl until the float raises a tapered valve which prevents any more gas from entering. If this valve is defective gas continues to overflow the bowl, and enter the crankcase through the intake (and raises your oil level). The valve is easily removed and replaced. Just remove your air filters complete with all tin, and unscrew valve assembly with 11 or 13 mm socket.
Hope this helps
Matt
Matt Macpherson
1973 911
nvalve@yahoo.com
Old 05-05-2003, 08:38 PM
Gasoline User
1974carrera's Avatar
Originally posted by 911pcars
Stuck float, high fuel (float) level or excessive fuel pump pressure. Look down the carb throats during idle.....http://members.rennlist.org/911pcars
B] Just be sure to use a mirror[/B] to look down the carb throats while the engine is running...you can lose an eyebrow, or worse, if you're looking down the carb and it pops back through the throat.
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 05-05-2003, 09:35 PM
