Junk Car Aficionado
Issues with Adjusting Fuel Mixture
Hi Everyone,
I just got done fixing a bunch of vacuum leaks on my CIS 1975 Porsche 911S but now my car seems to be running worse. I think the engine might be running too rich since I was reading that people tend to richen up the mixture to compensate for vacuum leaks. I followed the CIS tuning section on how to adjust the fuel mixture but my adjustment screw will not turn. I put quite a bit of force on it but I am afraid I could break sometime if I really give it some muscle. I put some DW40 in there but still nothing. Does anyone know if I could break something expensive if I apply too much torque? Has anyone else had this issue as well? I really don't want to have to take the intake system off the motor again! Thanks in advance for the help! Cheers! Alex
1977 Porsche 924 (2003-2005) 2003 Porsche 911 (2017-2019) 1975 Porsche 911 S (2019-present) |
Are you sure the allen key is entering the adjustment screw? If you haven’t done it before it could take some practice. Worst case is that you round off the adjustment screw and have to pull the air metering plate and force the screw off in a bench. Keep trying some penetrant. If you damage the screw it would not be expensive in terms of parts but definitely a pain in terms of labor.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! Last edited by Dr J; 05-02-2021 at 04:58 AM.. |
I find a tight one occasionally. Never stripped one using more force.
Junk Car Aficionado
A longer 90 degree angle on the tool helps.
you can order from Stahlville company the correct tool like this
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Fuel mixture screw.........
Place a piece of rag in the air box directly under the access hole. Push the lever up and spray some penetrating oil through the hole. And saturate the fuel mixture screw with penetration oil and allow to sit for a while.
If you raise the arm or lever of the sensor plate, the top of fuel mixture screw could be seen partially. See picture below. Spray some penetrating oil and allow to soak. ![]() Make sure you got the Allen wrench key engaged properly and turn it left and right. There is nothing to worry about the breaking something. It is built well and strong as a tank. ![]() Tony |
Junk Car Aficionado
Thanks everyone I was able to adjust the mixture it's still rather hard to turn but at least now with a pliers I was able to adjust it and I got the car running a little better. My next question is where is the best place to get an exhaust gas analyzer? Would anyone have one in the Chattanooga area I could borrow? The cheapest one that I can find is $250 on Amazon.
don`t waste you buck..try to find a friendly smog station nearby who would let you check it
ivan
