1976 2.7 911s MSD 8910
Boosted by recent success of getting the car running will I have decided to tackle the nonworking VDO tach:
MSD 6AL 6425
123 Tune USB distributor
BitzEFI megasquirt ms1
The 6AL is triggered by the white wire, magnetic pickup not used.
I have sketched how it is configured with question mark on how the VDO tach wire should be connected.
Old 05-02-2021, 05:51 AM
I didn’t need a tach adapter for my ‘77, not sure if you need it either.
Rutager West
Old 05-02-2021, 08:18 AM
VDO tach doesn't work if connect to MSD grey. The 8910 doesn't seem to have helped either!
Old 05-02-2021, 08:30 AM
I just looked at my MSD box on the shelf and I have the blue wire cut and the grey wire was used for tach.
Are you sure your tach even works? I think you said that the PO didn’t have everything set up very well?
Rutager West
Old 05-02-2021, 12:58 PM
Quick note: if your Bitz is working off of the grey wire, your tach should too.
Rutager West
Old 05-02-2021, 01:01 PM
