David 23's Avatar
Non-Porsche tool kit for travel?
I need a tool kit for my canyon carver. I don't need a $500 Porsche kit, I just need a range of metric tools in a case or roll that would function when needed. Most of the inexpensive auto kits on Amazon are half SAE. Anyone have a link to an inexpensive all metric kit that has combo wrenches, sockets, a wrench etc. that is compact?
1979 911SC 3.2 SS Custom Backdate Hot Rod
1972 911T, 2.7RS Spec
Beck 904 Carrera GTS /3.6
2023. Macan
Previously owned several 911 models since 1975.
Old 04-30-2021, 04:59 PM
Check out Tekton tools. I'm continually impressed with them at their price point. Mostly made in Taiwan, some are made in USA.
Kinda the equivalent of 1990s made in USA Craftsman.
Old 04-30-2021, 06:00 PM
My car came without its tool kit.
I bought an inexpensive tool roll on Amazon and filled it with Harbor Freight tools (metric combo box wrench set, multi-blade screwdriver, pliers, spark plug wrench w/ extensions, some sockets and a ratchet, etc). Emergency use only, right?
I bought a “bucket boss” tool roll (amazon) and filled it with some box-end wrenches, a HF driver and sockets, a screw driver set (from HF) and then a couple things that are kinda P-car specific, like the fan-tool holder. I also grabbed a breaker bar, and put a lug-nut sized socket in the mix. My wife made a little bag to hold the whole mess inside out of a pair of extra-huge Levi’s from Salvation Army so that the *stuff* that I want to have in there as ICE stays in one place.
My car (several owners deep I believe) “lost” it’s spare tire and the tool kit the car came with. So: rather than breaking off the time, energy and such to get a correct tool roll, I spent less than 100 with this set up. I replaced the metric wrench set in this kit with a HF one.
I could take a picture of the current set up if you’d like, but I think that you get the idea....
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html
Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things.
Old 04-30-2021, 08:29 PM
Ctopher's Avatar
I got a Stahlwille Christmas calendar wrench set, a Klein adjustable length screw driver and zipper bag and threw in a old set of Craftsman 3/8 sockets, extension & ratchet. I added the lug & fan wrench with the fan tool. Beyond some basics like electrical wire, zip ties, tape and the other odds and spare fuses, etc that you might expect to need. They easily tuck in front of the spare tire without moving or rattling.
CTopher
Old 05-01-2021, 08:35 AM
Banned
Just buy the sizes you need (HINT: DIN) and a tool roll separately.
Hazet & Stahwille give you that Germanic schadenfreude
or Ko-ken has top quality tools for decent prices
or Tecton has decent quality tools that seem to be from Taiwan
Old 05-01-2021, 11:49 AM
Seems the key is to put together a targeted set like Robey5 did and make sure you have the tools (and supplies) needed to accomplish basic roadside repairs that are unique to the 911 (and therefore unique to the 911's tool kit) -- specifically, make sure you have a proper Lug Wrench (and jack), the 911-specific fan wrench tool (and a spare fan belt), a wrench/socket that can fit the fan nut and (perhaps) a spark plug wrench that would work well with the 911's plugs -- add in a few strategically chosen screwdrivers/metric sockets/wrenches, etc. and you'd be able to tackle foreseeable problems.
Old 05-01-2021, 12:11 PM
HarryD's Avatar
I did this for my VW Bus. Went to harbor freight and got:
1/4 & 3/8 socket set. Made sure I had a spark plug socket.
Set of combination wrenches. Made sure I had one to fit fan pulley.
Set of screwdrivers.
Allen key set.
Multimeter.
Box of electrical connectors and a crimper.
Channel lock pliers.
Slip joint pliers.
lineman pliers
Box cutter
Zip ties
Lug wrench
Tire slime
Jack
Bag to put it in
For parts
Fan belt
Spark plug
Points
Pieces of wire.
Lug nut
A few fan shims
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-01-2021, 01:38 PM
