-   -   New headlight switch help needed (http://forums.pelicanparts.com/porsche-911-technical-forum/1091891-new-headlight-switch-help-needed.html)
Harpo 04-25-2021 08:56 AM
My new headlight switch is slightly different than my original switch
http://forums.pelicanparts.com/uploa...1619366110.jpg
Harpo 04-25-2021 08:59 AM
The new switch has a "N" and 75 that are not on my old switch. Could "N" be same as "K"?
proporsche 04-25-2021 12:07 PM
i do not know if this helps you found this on net..
Ivan
http://forums.pelicanparts.com/uploa...1619377603.jpg
Harpo 04-25-2021 02:10 PM
Thanks, nice photo with added notes but unfortunately it doesn't answer my question of does "N" = "K"
creaturecat 04-25-2021 06:42 PM
the provided pic indicates N = K
is this a trick question? :)
Harpo 04-26-2021 03:18 AM
Sorry was not meant to be a trick question. I just don't see how N = K
LIRS6 04-26-2021 05:48 AM
Population growth rate declines with population numbers, N, and reaches 0 when N = K.
techman1 04-26-2021 07:07 AM
I think creaturecat was linking your diagram to the photo. When comparing the two your n corresponds to the k. I would want more assurance than that.
Canada Kev 04-26-2021 07:26 AM
I can't say about the K terminal, but N is for your license plate and ashtray light.
I see in the image above that K is marked as the ash tray and high beam indicator light, so they likely are the same.
86 911 Targa 04-26-2021 07:57 AM
Switch.
Post deleted.
Gerry
86 911 Targa 04-26-2021 08:32 AM
Originally Posted by 86 911 Targa (Post 11310483)
Hello all,
Actually, I was the original poster of the switch nomenclature
as posted by proporsche during the installation of a new switch
on our '86.
It is accurate.
Best,
Gerry
pm me as needed.
http://forums.pelicanparts.com/uploa...1619451121.jpg
FYI
proporsche 04-26-2021 12:34 PM
good job Gerry.,n both pictures....had no clue it was from you
Ivan
