911 Quarter Window Install
I need to install the passenger side rear quarter window in my 1988 Carrera. What is the proper sequence of the install?
Thanks in advance for your response to my question!
Old 04-26-2021, 07:10 PM
TTT....There has to be someone who installed a rear quarter glass during the painting process.....please advise as to my question. Thanks
Old 04-29-2021, 03:52 PM
Subscribing... Doing the same soon.
Old 05-02-2021, 09:22 PM
Alan L's Avatar
From memory fairly straight foward. A bit of vaseline on the rubber lip, a cord wrapped 1 1/2 times around the rubber groove. Install from outside, pulling the lip inside. A rubber mallet is useful to help snug the outside rubber in place. Then fit the beading - again rubber mallet may help. It is a long time since I did one but I think that was the general process. I recall it wasn't too bad - except getting it oriented just right so it snugs in was important. It gets tight in the corners from memory. You have the inside trim already removed of course.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-02-2021, 10:04 PM
fred cook's Avatar
One thing I learned from doing this is to start the front edge first and work towards the rear "pointy end". I first tried inserting the rear end of the glass but could not get the rest to seat properly. Starting with the front edge made it a much easier job. Good luck!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-02-2021, 11:26 PM
