Increasing compression in 2.7?
A local 911 engine builder claims to have good experience from removing material from the cylinder heads to increase the compression from 8,5:1 to 9,5:1. He uses shims to compensate for the removed material in the valve train. This way I could still use the low milage cylinder/piston set in the car.
Does anyone here have experience with this procedure? It will be done on a set of spare cylinder heads that I have lying around so that the originals will remain untouched. The plan is to combine this with 964-profiled cams to hopefully get around 200hp from my otherwise stock 2.7 1977 911S (SSI/Dansk headers and exhaust). |
sounds like smoke and mirrors
the only way you can remove material to raise comp ratio is to fly cut the head That would be a lot of cutting, shims reduce comp ratio the thicker the shims get. the 964 cam is a poor choice for performance , it is an emission cam . just some thoughts Ian |
He giveth and he taketh away. My example may not be yours exactly, but I put a 2.7 kit in my 2.4 motor, 8.5 to 1. Drove it that way for a number of years. Went back in, cut the heads .040'', had to cut the pockets a bit, (MFI engine with 4.5 S cams) and raised it to 9.5 to 1. I had to massage the left side cam idler arm a bit and made stainless steel lash caps for the tensioner pistons so that the piston didn;t ride too high out of the tensioner body. That extra bit of compression is worth it. Bob
Yes, I plan to keep the CIS, so that limits the choice of cam profiles. Dougherty Racing also has some which are supposed to work with the CIS.
The procedure described by @r lane is similar to what my engine builder suggests, I guess. |
I wonder how a set of non CIS style 9.5 pistons would do in a CIS motor? I'll be in that same boat soon with my stock 2.7, and have been thinking about SC cams and a compression bump..
Here is some info on CIS performance .
https://forums.pelicanparts.com/porsche-911-technical-forum/1073886-3-0-rebuild-performance-advice.html Ian Page 1 post # 19. specs on engine Page 2 post # 22 Dyno sheet |
| All times are GMT -8. The time now is 12:24 AM. |
