-   -   HOW DO I get the ignition rotor off????? (http://forums.pelicanparts.com/porsche-911-technical-forum/1092324-how-do-i-get-ignition-rotor-off.html)
Knight77911 04-30-2021 11:06 AM
Okay, everyone, try not to laugh too hard, but I CANNOT get the ignition rotor off. What's the trick? I'm afraid if I pull any harder, I'm going to break something.
1987 Carrera 3.2
Ian Comerford 04-30-2021 11:23 AM
It should just pull off. Try two screwdrivers on opposing sides under the lower surface of the rotor arm and push against the distributor casing if that makes sense
chrisbruck 04-30-2021 12:08 PM
Hopefully you don't need to go ballistic on it but I had one similarly stuck on my boat and took a Dremel and cut a slit in the plastic part of the rotor careful not to nick the distributor shaft and took a big wide screwdriver and pried it apart and it popped free quite easily.
AlKidd 04-30-2021 12:11 PM
I ended up using a piece of flat steel and a pry bar to get mine off. It was one of the rpm limiting ones but acted like it was glued on. No chance of saving it ether.
Knight77911 04-30-2021 12:13 PM
Okay, I'll try these suggestions. Thanks!
jlex 04-30-2021 12:38 PM
I've cracked more than one trying to get them off. Have a spare ready to go. Put a bit of grease on the shaft before installing the new one.
