-   -   Turn Signal Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/109234-turn-signal-problem.html)
Fassi 05-04-2003 12:23 AM
Turn Signal Problem
Hi everyone,
Please advise on the following problem:
--Operation of the left turn signal fries the fuse immediately.
--Parking lights operate normally.
--When the car is off, the left blinker will remain lit when you operate the stalk.
What is the most likely cause of the short?
Thank you very much!
Fassi 05-04-2003 10:23 PM
anyone :) ?
kcope 05-04-2003 10:37 PM
Turn signal on but not flashing when the lever is acuated right or left and the car is off is normal.
As for cooking fuses, let me check the diagrams. Check and make sure all your ground wires are tight and making good contact. Its probably not the problem but somebody is going to tell you that so it might as well be me. :rolleyes:
kcope 05-04-2003 10:41 PM
Which fuse??? box and number. Should be box 1 fuse# 8. fuse 9 or 10 would be too much to hope for.
