-   -   Get it while you can… (http://forums.pelicanparts.com/porsche-911-technical-forum/1092568-get-while-you-can.html)
tirwin 05-03-2021 08:26 PM
Looks like R-134a and other refrigerants are going to be phased out…
https://www.npr.org/2021/05/03/993054374/epa-moves-to-cut-a-powerful-greenhouse-gas?ft=nprml&f=1007
RDM 05-03-2021 11:53 PM
Great for refrigeration companies. Not so good for the rest of us.
What do they suggest we use instead?
MrBonus 05-04-2021 01:39 AM
Roll down the window, feel the warm air through your hair.
tirwin 05-04-2021 03:42 AM
R-1234yf, R-152a and R-744
Apparently, R-134a will not phased out the same way R-12 was eliminated, which was to restrict production. It appears R-134a will be economically starved out over the next decade or so.
I don’t know anything about the 3 replacement refrigerants. Are they a direct replacement or do they require adaptation? Honeywell seems to say 1234yf is a drop-in replacement with the same characteristics and no adaptations required.
https://www.honeywell-refrigerants.com/india/wp-content/uploads/2013/03/honeywell-solstice-hfo1234yf-atlas-copco-case-study.pdf
tirwin 05-04-2021 03:53 AM
According to this article…
https://www.underhoodservice.com/is-a-new-refrigerant-going-to-replace-r-134a/
…1234yf will require different service fittings, a different PAG oil and will not be available to DIYers.
MBAtarga 05-04-2021 04:12 AM
And converting my SC to 134a is on the to-do list! I guess I go ahead and get it done.
1989Carrera 05-04-2021 09:44 AM
I'm going the other way. I bought a 30 pound jug of R12 so I'm going to convert back to R12. Since I was getting "acceptable" cooling due to all the Griffith's upgrades, I should have even better results with R12.
HarryD 05-04-2021 12:25 PM
Be sure you have installed the modern barrier hoses to prevent the flow loss of you R12. Also. Be sure your lubricant and compressor are compatible.
1989Carrera 05-04-2021 12:43 PM
I have quite a few of Griffith's products already: Barrier hoses, evaporator & hurricane evaporator motor, variable speed fan controller, etc.
I will be working with Charlie at Griffith's to make sure I get everything right.
manbridge 74 05-04-2021 09:04 PM
Funny thing is R12 was never eliminated as it’s the most efficient refrigerant for automotive use. Can be found with only a little effort. I’m sure R134a will be “eliminated” in the same way...
GH85Carrera 05-05-2021 05:49 AM
What about the days it is 100+ degrees and 90% humidity in Houston or Savannah? Drive to Key West, FL in the summer and tell me you don't want AC.
I will stick to my Air Conditioned nice cold car.
GH85Carrera 05-05-2021 05:55 AM
Great choice. My system is all replaced except the front condenser and the engine compartment condenser. Every other part has been upgraded. I love the variable speed fan switch and the cold air. It works so well that on a 12 hour drive in 100 degree heat driving due west with the sun shining through the windshield on my chest I had to turn the temp knob UP because I was getting cold.
My wife is happy to ride with me in the summer heat. We have been to 41 states in comfort, and plan to hit all 48 continental states in my 911.
tirwin 05-05-2021 11:48 AM
What can be found is old stock. R12 hasn’t been made since the 1990’s.
manbridge 74 05-05-2021 03:19 PM
Not true. I got the certification and buy it in bulk regularly from HVAC supply stores. I will look for a date on container but it’s certainly not old stock.
pmax 05-05-2021 03:23 PM
Cold temperature tolerance tends to weaken as we age.
Just saying !
But back on topic, looks like there's already a run on it, my order may be cancelled due to lack of stock.
creaturecat 05-05-2021 03:51 PM
Red Tek works nicely.
tirwin 05-06-2021 04:35 AM
It is true.
R12 hasn’t been made internationally manufactured since 1996. It’s either old stock or reclaimed.
R12 : Refrigerant Freon Refrigerants R12 Refrigerant Dayton Ohio
tirwin 05-06-2021 04:40 AM
Just saying !
You live in the Bay Area. Your opinion doesn’t count. LOL
manbridge 74 05-06-2021 08:06 AM
http://forums.pelicanparts.com/uploa...1620316947.jpg
June 2015 in lower corner...
Its been discontinued on paper only. Always been available and I don’t hear from my supplier that it ever will be...
Coastr 05-06-2021 07:55 PM
R12 was about ozone depletion, the cause de jour of the 90s. R134 is about greenhouse gas, the current crisis de jour. The issue is that refrigerant gasses work because of specific properties around boiling points and densities. You can move that around with different pressures but ultimately you’re going to get a gas with measurable global warming potential.
Ultimately there is far too many r134 systems out there for it to go away any time soon, but stockpiling over time is a smart move.
The people that govern you don’t like you and want you to stop enjoying yourself, because your pesky nonconformance ruins their spreadsheets. Progress in life requires making peace with this and adapting accordingly.
tirwin 05-06-2021 08:17 PM
It’s reclaimed and purified. Again, it’s production was banned under the Montreal Protocol and hasn’t been made since 1996. If someone is making it they are risking huge fines from the EPA (at least in the US).
In some countries R12 is reclaimed and destroyed. Most A/C techs I’ve talked to locally say they don’t even have the equipment to recover it anymore.
manbridge 74 05-07-2021 07:34 AM
Hard to say if anyone is making virgin R12. Certainly seems suspect that a lot of reclaimed or otherwise R12 makes it up from Mexico each year. It’s been 25 years of “get it while you can.”
