Fuel tank Bango fitting
Looking for some help in locating this banjo fitting for my 73T fuel tank.
Thanks Mike
Also have a question about these types of fittings. First of all looks like I slid the part of the fitting that the fuel line connects to on backwards for the picture as the threaded end threads into the tank and fuel line connects in the opposite direction.
I had a local shop replace the front pan in my car and it looks like they must have kinked the fuel line when putting the tank back in. My question is should there be a copper washer on both sides of the banjo fitting? |
Enginerd
This isn't exact, but maybe it's close enough you could find one and slightly modify it?
https://www.belmetric.com/banjo-elbow-fittings-c-1041_933/
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS IG: @pcar911fan |
I can't post a link but stoddard has what you need. The part is SIC-356-049-00 the porsche part is NLA 90135604900. Also yes there are 2 sealing rings on both sides of the banjo.
https://www.pelicanparts.com/More_Info/90012300760.htm?pn=900-123-007-60-OEM
1979 930 |
TxGerman and rxtrom thank you very much for the replies I will check with them.
Thanks Mike |
Thanks Gomezoneill
