Sunroof help!
I have an 84 3.2 carrera with a sunroof that rattles only when open. Does anyone know what it maybe? If I grab the sunroof fro the interior and pull down of the front edge of the sunroof the back of the sunroof lifts a little and there is the rattle. What’s causing the sunroof to lift up on the tracks?
Antonio |
Antonio..it could be several things.There is plenty of culprits.Take your time and do use the search button on top right....
I`d suggest do some reading 1st. After you know a little more pull down the sunroof bottom cover -headliner and see inside .also open the sunroof and take a pictures and post it here we will help you if wee anything obvious ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
![]() This is the culprit I believe. I unscrewed the flathead and now it doesn’t tighten down. How does this piece work? Antonio |
This does up and down when the roof is open which cause me the sunroof to rattle of bumps when driving
if you loosen the bolt the nut from behind has fallen off..look for it..plus the spring clip should be on the pin extension of the cable guide..be careful now moving it you have a nut somewhere in there
Ivan
Ok thanks. Does the sunroof supposed to push and down when fully open? Meaning the bolt extends up when fully open. Which makes the roof rattle of bumps
Antonio....as i have suggested do some research and reading so you get the idea how it works..you should not be able to push the roof up by hands ,for that there are the cables.
Start with disconnecting the el.motor under the zip on your headliner ..then you can move the sunroof manually...be careful not to scratch you sunroof ivan
How do you get that nut back on? I can’t figure it out
for that .that sunroof has to come out of the car-gently be very careful....and again use the search button...........
Ivan
Thank you for your help really appreciate it. I removed the sunroof carefully and successfully and replaced the nut that fell off. Upon having the sunroof off, I went over the mechanicals. One thing a noticed and not sure if it maybe my problem, the guide that runs inside the aluminum is a little loose when I tried to move it. Not sure if maybe the cable needs to be tighter. If that’s even an option. But I believe that’s what’s maki g the roof rattle when fully opened.
take a picture of it...if you are talking about the guide which is part of the cable...it has to be loose...lubrication will helb if it makes the noise...
Ivan
I’m going to try and explain it a little more. When you close the sunroof and it lifts maybe about an inch at the very end to seal properly against the felt seals. That’s the play I’m getting when the sunroof is fully opened. That one inch play from the rear of the sunroof (rear meaning engine rear).
If I grab the edge of the sunroof when fully open and pull down the rear edge of the roof inside the roof cavity comes up about an inch. I’ll try and take pictures or even a short video. |
This is my issue. Not sure if it’s normal sunroof function.
https://youtu.be/eRct6hftZfQ |
well?...i double checked now mine and if i disconnect the headliner almost the same play ..try to connect the headliner that will keep in place because the headliner slides inside the rail...on the side
Ivan
Does your sunroof rattle (move) when fully opened at highway speeds over potholes or imperfections on the road? |
The Bentley states 4 guides but if I remember correctly I only have 2 left and right on the front (headlight front) sunroof panel |
Do you have a picture of the sunroof headliner orientation? |
wait i go to the car....
