-   -   Cam Sync - AEM Infinity - Starting Issues - Cam Sync (http://forums.pelicanparts.com/porsche-911-technical-forum/1092878-cam-sync-aem-infinity-starting-issues-cam-sync.html)
mikedsilva 05-08-2021 03:28 AM
I've been running an AEM Infinity 506 with no real issues. I recently had the motor out to swap back to a set of cams that I had initially used and wanted to experiment with again. The cam/crank sensor which mounts in place of the distributor was not removed, and nor was the crank pulley.
First start was not an issue. Fired up, did the cam break in, etc
After that, it was very difficult to start. I played around with my cranking afr and timing etc but couldnt understand what had changed so much. Even fitted a new set of plugs but that didnt make much difference.
I managed to get the car running and bed in the engine and change oil etc, so all good there. But I was scared to park up anywhere but home... it was taking 20 plus tries to get started.
Today I sat with a friend who looked at my diagnostics tab in the AEM software.
While cranking, I quickly got sync state 100% and it would try to fire and bang (like gunshot) and carry on but not run. When it eventually did fire up, it ran fine. We noted that the "Cam 0 Timing Degrees" on the Diagnostics tab, was reading 475 degrees. We turned off, and tried to restart.. this time, when it wouldn't start (even thought it said I was in sync) the Cam 0 Timing Degrees was showing 116 = basically 360 degrees out.
He thought that perhaps my crank pulled sensor was 'noisy'... but again, it was running well up till this point. He altered the noise settings in the wizard and it did seem to be easier to start but was far from repeatable. We had to use an auxilliary battery.
Looking at the cam/crank sensor, it is designed in such a way, that the sensor is not perfectly over the middle of the toothed wheel on the pulley. So I removed the cam/crank sensor from the motor and was careful NOT to rotate the pinion. I elongated the hole in the housing slightly with a dremel, then reinserted the cam/crank sensor and made sure it was centred over the toothed wheel, and also 1mm or a fraction less distance from the teeth.
I rechecked my ignition sync anyway... with ignition lock in the wizard at 0, and the fuel pump and injector relays removed, I cranked the motor with a timing light and got 0deg at top dead centre. Does this support my efforts to not roate the pinion on the sensor while it was out of the motor?
I went to fire up the motor and it did not fire. I still got all green boxes to say I was in sync, but this time the "Cam 0 Timing Degrees" was reading 296 (earlier today it was 116) = ie, 180 degrees difference.
Turn key off, and on again, and this time, it syncs showing 655 and it fires right up.
So I don't understand why it sometimes syncs 360 out from when it should?
And also, how I managed to be 180 out on the reinstall, if my ignition sync did not need to be altered? Does this mean I must have knocked the pinion? But if so, wouldn't that mean I would need to make adjustments on my ignition sync?
I'm confused...
Here's a short video
https://youtu.be/A_xwB9m0GN0
Harpo 05-08-2021 04:01 AM
Subscribed
icarp 05-08-2021 04:01 AM
Mike , it sounds like the pick up sensor in the unit is going bad or the wire .
just a thought
Ian
mikedsilva 05-08-2021 04:20 AM
just a thought
Ian
possible...
looking at the Rasant Manual I got years ago, it talks about ignition sync but that was when they had the EPM module..and I got the later updated cam/crank sensor.
Back then, they said the EPM module had two discs inside the EPM: one has 24 “teeth” which provides the crankshaft position signal to the ECU, while the other has 1 “tooth” and provides the camshaft signal.
I'm a bit basic when it comes to electrical things.. I got the cam/crank sensor and use a 60-2 tooth gear on the crank pulley. I'm assuming my 60-2 wheel replaces the 24 teeth in the old EPM.
Is the coarse timing adjustment (CamSyncAdjustment) in multiples of 30 degrees? ie, if you put a "1" in the box, does that mean 30? I'm thinking I need to go back and re do this as I have "36" in mine.
mikedsilva 05-08-2021 04:21 AM
just a thought
Ian
But which sensor... the one on the flywheel? or the one in the cam/dist sensor housing?
dannobee 05-08-2021 05:38 AM
If you didn't mess with the cam sensor or the crank sensor, that leaves the wiring as the most likely suspect. Validate with a multimeter and the wiggle test. While I'm not familiar with the 506 specifically, most ECMs, both factory and aftermarket, only need to see the correct sync for one revolution for it to fire the ignition correctly. If the failure occurs during a drive cycle, it just won't start on the next try. Which is pretty much what you're experiencing.
Mr Beau 05-08-2021 10:25 AM
Can you ignore the cam sync and run in waste spark?
mikedsilva 05-08-2021 01:20 PM
Not sure I understand "failure occurs during a drive cycle"... ?
For some reason, during crank it syncs 360 out of phase sometimes and of course will not start. Could wiring or connection cause it to sync incorrectly?
Also, the Cam0_SyncError1 and Cam0_SyncError2 are incrementing while the engine is running = that isn't normal is it?
Don't know and not sure I should?
mikedsilva 05-08-2021 09:10 PM
Spent some time checking my grounds. The wiring harness from Rasant has 2 grounds in the engine back that are spliced into the coil harnesses.. they ground onto the top of the engine into the cam housing location. Also double checked my ground on the trans strap where the ecu ground attaches.
I cleaned everything and tried again.
This time, I got 1 or 2 failed starts and then it started several times in a row.
Ie the cam sync was picking up correctly.
But 10 minutes later, I was getting failed starts and it was trying to sync 360 out of phase.
A friend is going to loan me a scope and I guess we will see what signals we are getting.
What can cause an "erratic" sensor? and also, if the sensor was indeed faulty, why does it run perfectly fine once it actually does start?
Harpo 05-09-2021 03:49 AM
Have you asked Andrew and /or Infinity?
stownsen914 05-09-2021 04:51 AM
Random thing - I had an issue setting up a car with a Motec, not sure if it might be possible with an AEM. During cranking the ECU needs a certain minimum voltage to power it. It's not uncommon for voltage to drop to 8 volts or less during cranking, which in my case was causing the ECU to not work properly. Easy enough to check in case AEM has a similar minimum voltage. The solution for me was a more substantial battery.
'78 SC 05-09-2021 05:54 AM
Originally Posted by mikedsilva (Post 11324784)
possible...
I'm a bit basic when it comes to electrical things.. I got the cam/crank sensor and use a 60-2 tooth gear on the crank pulley. I'm assuming my 60-2 wheel replaces the 24 teeth in the old EPM...
So you're using just the sync (cam) signal from the EPM and getting the reference (crank) signal from the 60-2 crank pulley wheel? Are there two connectors on the EPM? Are you using the correct (cam sync) one?
just spitballing,
mikedsilva 05-09-2021 05:54 AM
yes
no reply as such yet
mikedsilva 05-09-2021 05:57 AM
just spitballing,
hi Steve
yes, there are 2 sensors. They have different plug types and cannot be plugged in incorrectly. Here is the setup I am using. https://rasantproducts.com/collections/engine-sensors/products/rasant-products-cam-crank-housing
As mentioned, this system was working perfectly a few weeks ago, before I pulled the engine to swap camshafts.
Thanks for the suggestion though.
mikedsilva 05-09-2021 06:00 AM
Hi, yes thought this might be something. I have had the battery on a charger and also using a portable jump pack. Cranking speed is strong and battery level is good.
Today it went form syncing correctly every so often, to now where it is not syncing correctly at all. It will not start. I have borrowed a scope tool to try to inspect the signals coming from the sensors.
I'm hoping it's a failing cam position sensor as that is relatively easy to replace.....
<iframe width="560" height="315" src="https://www.youtube.com/embed/p4kRDZbaT1I" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
dannobee 05-09-2021 06:07 AM
"Drive cycle" starts when you turn the key and it fires up and ends when you turn the key off. There are different strategies in the ECM to address failures, like when the cam sensor signal is lost. But often the ECM "remembers" the last correct cam sensor signal (it is firing the ignition and injectors, after all) and can keep the engine running without the cam sensor signal. It only needs the cam signal on initial cranking, to properly fire the ignition and injector sequence (if it's sequential injection and not batch fired).
Since this started after cam replacement, what changed? Wiring? Was the cam sensor bumped or damaged? Is the crank sensor gap the same?
icarp 05-09-2021 07:07 AM
Andrew and Rasant /or Infinity? were having trouble with the sensor for a while .
This could be the same gremlin. It had to do with the 60-2 and the sensor specs .
Ian
mikedsilva 05-09-2021 08:30 AM
Hi
the cam/crank sensor housing and its sensors were left in the case and not removed while the cams were swapped. Also, the crank sensor gap was exactly the same since the pulley was also not removed from the engine.
mikedsilva 05-09-2021 08:31 AM
Ian
Still hoping to hear from Andrew... no reply yet...
mikedsilva 05-09-2021 10:40 PM
So, it appears to be "fixed".....
I don't quite understand why tho... there was another thread on Pelican that I forgot about, where the original poster had an almost identical problem to me... pulled engine, swapped cams, reinstalled and no run. He ended up ditching the AEM and going with Link or Haltech (I forget which one). Another poster in the same thread ended up upgrading his firmware and seems to be running OK. I was hesitant to upgrade firmware and at this point, still have not.
I borrowed a scope tool that plugs into your laptop.. and managed to scope the cam position sensor and the crank position sensor. First time I used a scope.. took me hours to figure it out and the scaling and stuff.. still not right but just wanted a visual.
I sent vids and pics of the results to a friend to confirm that the sensors were indeed sending the correct signals. And they were. So it wasn't a failed sensor. Now this is the part that I dont understand....
It was working before fine..
Then it began to start only half the time...
Then it wouldnt start EVER.
It was suggested to remove the cam sensor, rotate the pinion, and try to get it to sync on a different part of the cycle. I wasnt exactly sure what I was aiming for.. after rotating it 180 degrees I still got a no start event. Roating 90 from there, and still no start. Rotated again and ended up syncing at 56deg according to the Diagnostic tab in Infinity Software. Looking at the scope, it shows the cam signal on top, coinciding with the missing teeth signal of the crank pulley.
But now it starts every time and I have no more Cam Sync Errors.
Is this considered fixed?
If it is, then why did it work before, and then work less and finally not work at all?
No sensors have been changed.
Here's my vid.. please don't laugh, I don't understand electronics at all.
<iframe width="560" height="315" src="https://www.youtube.com/embed/6s62a4U7xx8" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
'78 SC 05-10-2021 03:28 AM
Congratulations, Mike. Good news, though getting something to work but not understanding why it works (and why it stopped working) can be frustrating.
Is this one of the threads you are referring to? Hall sensor EFI madness
At this point, do you believe the basic problem was the "phasing" of the cam synch signal relative to TDC? Even though you did not rotate the pinion on the EDM initially, you could have effectively rotated it 180* by installing the cams on the "other" TDC. The fact that it started first time for the cam break in but would not start reliably after that is confusing, though.
When the problems started, you resynced the cam signal without moving the EDM, though it did not seem to be stable and you were getting sync values >360*. Only when you eventually pulled the EDM out and physically rotated it various amounts (180*, 90*, ??*) could you get to no Cam Sync Errors. Don't ECUs have restrictions on where the cam signal needs to be relative to TDC? Like within x degrees of TDC? Rising edge versus falling edge?
Glad you're up and running, looking forward to the comments on this.
mysocal911 05-10-2021 04:47 AM
That an absolute necessity (no distributor), especially when you have such a wide cam pulse width signal.
Typically, a cam position pulse signal width is about the same as the crank signal pulse width,
and not multiple crank pulses as seen on the scope waveforms, i.e. one cam pulse for every two crank rotations.
Dr J 05-10-2021 08:43 AM
Congratulations on solving Mike. In hindsight I looked at the MSX3 manual because it talks about cam tooth vs crank. . I know you are using the Infinity as I am, but I still use the MSX3 manual as a good source of info for EFI. Maybe before the cam edge was close to the missing tooth.
http://forums.pelicanparts.com/uploa...1620661364.jpg
mikedsilva 05-10-2021 01:55 PM
Hi Steve
I wish I was smarter.
I DON'T understand exactly why it is working now. Your comment about installing the cams on "the other TDC" sounded good, except when I rotated the cam sensor 180, that should have effectively put me back on "the other tDC" and it still didn't fire. In fact it carried on and backfired exactly the same. Here's a lesson, don't stand in front of the exhaust pipe when cranking... my shirt melted, and all the hair on my stomach and left leg got singed!!
I feel it has something to do with picking up the cam signal first, before the TDC signal during rotation. The document posted by DrJ kinda explains it, but it also says the cam trigger can be anywhere during the revolution EXCEPT for in the middle of the missing teeth on the crank.. but if I am reading the scope right, isn't that exactly where my triggers are now aligned?
mysocal911 05-10-2021 07:39 PM
For proper syncing with the crank sensor, the timing of the cam sensor is based on the state change (plus to minus, or minus to plus)
of the signal and not the voltage level. If the ECU used the negative going edge of the cam signal relative to the crank TDC, then the
cam signal (negative edge) occurs about 70 degrees before TDC, based on the scope image.
Mr Beau 05-10-2021 07:57 PM
If crank sensor is 60-2 then you should be able to run batch/waste spark and not worry about the cam sensor.
jpnovak 05-10-2021 08:05 PM
MIke,
the 360 out is likely due to the noise on the cam inputs signal. This occurs about 36 teeth before the TDC indicator.
I suspect that the noise is crossing the threshold for negative edge trigger on the cam signal causing a false angle calculation. If this angle is different than the cam offset values it will increment the error counter and not start or misfire.
You have to find the source of that noise and eliminate it. First step here is to disassemble the top of The Rasant cam sync mechanism and thoroughly clean out. Check for metal shavings on the underside of the VR sensor and that the rotating bolt and surrounding surfaces are clean.
I have had problems where these threshold value settings in software do not specifically do anything to counteract noise. The hardware inputs on the ECU are also not filtered to reduce noise. You may end up building a noise filtering circuit on the cam input line. The most simple is done with a capacitor between signal and ground in combination with a resistor in series with the signal line. Higher order filters work better but are more complicated to install.
Mr Beau 05-10-2021 08:35 PM
Posted before seeing it was fixed. Probably what's happening is the ECU is looking for the cam signal at a particular location. You were close, but not close enough initially.
mikedsilva 05-11-2021 04:36 PM
thanks for all the responses.
I did remove the cam sensor from the Rasant housing to inspect.. clean as a whistle inside. Remember, this was working fine till I swapped cams and reinstalled. As some have said, it must have been something I had altered to cause the no-start situation.
I don't fully understand what Jamie was saying above but I suspect "threshold" and "false angle calculation" are def what I was experiencing.
My suspicion is that '78SC (Steve) was right that when I installed my new cams and retimed my engine, I might have set them so that the cam sensor was synced 180 out from when I pulled the engine. How would I have done this? Simple - by rotating the crankshaft 360 before starting my cam timing process as this would have rotated the Rasant sensor 180 degrees..... Of course I did not keep a track of how many times I rotated then engine when I was timing the cams.
The next thing I did, was pull the Rasant adapter out of the motor and re-aligned it to be more central over the crank trigger wheel and re-adjusted my gap (it was perfect anyway). When I re-installed it, I must have inadvertently rotated the pinion on the Rasant Sensor 1 tooth as it was now syncing at a different spot and the Cam0Timing Degrees was different to earlier that day.
Then I tried to rotate the pinion 180 but was still having issues. So from here it was pretty much guesswork to arrive where I am at now. I'm having zero CamTiming Errors. Took it for a drive, and seems completely fine. If anything, I think the starting is now 'better' than it has ever been.
In hindsight, when I first assembled the engine, it must have been a complete fluke that I got it running by aligning the cam sensor at the right spot, or one of the right spots. I don't remember the install manuals being so specific about where the signal for the cam needed to be in relation to the crank trigger. (apart from being 360 out and needing to offset).
So, going back to before I removed the Rasant sensor housing and rotated the pinion: could I have simply input another 360 into my Cam timing offset, to achieve sync on the other cylce of the motor?
jpnovak 05-11-2021 05:00 PM
Mike,
The only way to truly get this right is to use a timing light and set the reference angle so that a fixed timing "0" matches TDC on the light. Adjust the cam offset until they align.
If the engine does not start then you are 360 out.
None of the AEM documentation mentions anything about where the cam signal can be relative to the crank TDC Angle. Most systems are quite specific about allowable offset windows.
Glad its working well for you now.
