-   -   wheel bearing/spindle query (http://forums.pelicanparts.com/porsche-911-technical-forum/1093297-wheel-bearing-spindle-query.html)
Alan L 05-12-2021 09:40 PM
So my SC had some front wheel bearing play. Adjusted, no luck. Replaced bearings - still got play. Then I find a slight lip on the spindle underside where the outer bearing sits. I am guessing this is the problem.
Does this mean total replacement of the strut?
Alan
TxGerman 05-13-2021 03:42 AM
That's a great question. I just finished refurbishing/rebuilding my front end. My strut spindle was in great shape, but had it not been, I think the answer to your question is yes. If others know better, I am interested to hear as well. I suppose one possible alternative would be to take it to a machine shop and have them build up the area where the lip exists and have them re-machine the bearing surface, but that could become cost prohibitive relative to replacement.
MBAtarga 05-13-2021 04:59 AM
I'm going to say replacement is in your future.
Mahler9th 05-13-2021 08:17 AM
SC spindles are pretty robust. I have never heard of the type of issue you describe. Can you post a picture?
Solamar 05-13-2021 09:37 AM
Could easily be the DU bushings in the struts are worn. Feels just like wheel bearing play when the bushings between the strut cartridge and strut body wear out.
http://forums.pelicanparts.com/10837980-post11.html
Alan L 05-13-2021 12:06 PM
OK - pic as requested. This one is the original strut with the issue on the SC. I replaced it with a spare one off a dead SC that I had. Same issue. You can see the lip on the underside and inboard where the bearing sits. Some sight scuffing further out. The topside looks fine. At a guess I would say the lip is about 2 thou.
Would be interested to know which bushing is being referred to.
Alan http://forums.pelicanparts.com/uploa...1620936349.jpg
Dpmulvan 05-13-2021 12:34 PM
That spindle is not a big deal, I doubt it’s the cause of your issue. The bushings referred to are inside the strut housing, probably need to rebuild if there that old.
TxGerman 05-13-2021 12:44 PM
This….
https://uploads.tapatalk-cdn.com/202...7822742571.jpg
Alan L 05-13-2021 01:36 PM
Right - I just checked the link above - internal bushes in the strut.
Any threads on how to? Will do a search.
Alan
Solamar 05-13-2021 01:56 PM
Alan
A very obvious way to confirm that it is the strut bushings -
Remove the metal dust boot and reinstall strut in car, with the car on jackstands and wheel off, grab the strut at the point where the cartridge inserts the strut and push/pull. The play will be obvious if the DU bushings are shot.
Easiest way to replace the DU bushings? Send strut to Bilstien for rebuild. I chose to source the bushings from an industrial supplier (Elephant has them for sale as well I believe) and fabricate a puller on a slide hammer to pull the old bushings out, then press the new bushings back in.
Getting the bushings out is the hard part...
Solamar 05-13-2021 02:09 PM
DU Bush -
http://forums.pelicanparts.com/uploa...1620943708.jpg
http://forums.pelicanparts.com/uploa...1620943739.jpg
Alan L 05-13-2021 03:29 PM
Right - thanks a lot. Searched pages of threads - got a general idea and decided to pull the spare strut apart. Now I get it. The chrome insert is a sealed unit, with rubber bump stops at bottom. No worry about heaps of oil spewing. The bushes sit inside the outer strut tube. I can see 3 in there.
I could not detect any play - but I am prepared to re fit this one and see what happens. Meantime will make up a tool to extract the bushes while I wait for some new ones. Will sort an order. I have a 930 and SC so a job I probably need to nail at some point.
Will post something when I get the extraction nailed. The bushes will be some weeks away.
I have quite a bit of grease in there on the bushes. I see in one of the threads they say not to use grease - destroys the teflon coating. Light oil suggested. Anyone got experience on that? Thinking ahead to the install.
Alan
UROParts 05-13-2021 03:49 PM
Look into compounds like this, which fills gaps of up to 0.015" and has a 3,000 psi shear strength: https://www.vibra-tite.com/retaining-compounds/vibra-tite-538-high-strength-retaining-compound/
It would probably take 350°+ heat to remove the bearing race in the future (which would be fun when the bearing grease catches fire), but it could be an option of last resort.
Alan L 05-13-2021 04:15 PM
Right - thanks for link. Had wondered about something like that - just dubious if it would take the punishment.
Have just ordered some 50mm long bushes from UK. ERacing didn't seem to have them listed, Summit Racing did, but out of stock.
Got some on the way. Happy to try this first.
Now to get the old ones out. The fact there are 3 in there suggests may have been an issue previous.
Anyone know if there is a specified depth for the bottom one. Is there a lip to seat on? I have measured the top and bottom - but mine are 50mm and the old ones look like 40.
Alan
Solamar 05-13-2021 04:16 PM
Alan
Three bushes sounds like someone's been in there before. A shortcut is to press a third bushing in from the top, sliding the top one down as it goes in.
I heard the same thing about grease/teflon. Couldnt resist the urge to smear a bit of grease on the cartridge when I reinstalled though...
In the link I posted above, you can see the business end of the puller I made. It works on a slide hammer and was a major pain to get the bushings to move. If I do it again I'll have to come up with a better puller...
Alan L 05-13-2021 08:46 PM
Yeah - I am working on a plan. I have a lathe and a press. Still work in progress with no determined outcome/method yet.
FWIW I refitted the shock to the tube and looked for play. Zero. This is on the strut I had removed previously because I could not get rid of the bearing play.
Alan
stownsen914 05-14-2021 09:00 AM
The shock bushes in the struct can definitely cause a knock that feels like a loose wheel bearing. I had that exact problem on my racecar in fact.
Before you start replacing things, I'd look again at the spindle. If there is a detectable lip (i.e. can catch a nail on it), this isn't good. I have seen spindles worn like this. It will cause a wheel bearing knock, and there is no fix aside from replacing the strut. (I have heard that replacement spindles were available at one time, but I can't see how this would be worth the effort.)
You should be able to tell definitively whether the bushing or the spindle is a source of your problem. When my shock/strut bushings were worn, I finally noticed that I could feel the movement between the lower portion of the strut housing relative to the shock insert. You should be able to detect it by placing a finger between the strut dust cap and the strut, and shake the strut until you get the knock. If the play is in the bushings, you'll feel it there.
brighton911 05-14-2021 09:58 AM
Spindle wear on the bottom is not that uncommon. And yes, the cure is expensive, new struts. Been there, done that.
David Inc. 05-14-2021 10:29 AM
What are the telltales of spindle wear? Does it sound like bearing growl or more like clicking?
I ask this as my front end has been clicking for years now with several new wheel bearings and new bushings in the Bilstein strut housings.
Alan L 05-14-2021 12:00 PM
I can feel the lip on the spindle. So I am thinking a new strut - but will check the bushings won't fix it first.
"What are the telltales of spindle wear? Does it sound like bearing growl or more like clicking?"
Basically a clunk when you wobble the front wheel - same as a slack wheel bearing. Which basically it is. Except in the outer race rather then inner.
Alan
