Lifting Front End on 4 Post Lift
I just recently got a 4 post lift. In order to change wheels/brake work/whatever, how does one get the front end up? I got the rear in the air by lowering the lift down onto a lift stand that was positioned under the motor (with hockey puck). However, the front doesn't have a good center point to do that from as far as I am aware. Anyone have any good ideas? Thanks!
89 Carrera 3.2 |
Did your lift not come with a jack tray?
If so a couple of bottle jacks can work. I purchased a bridge jack for my 4-post last year, works on most cars, but still challenging to hit the lift points on the 84. Last edited by Quasimoto; 05-08-2021 at 04:41 AM.. |
Yeah I have the Jack tray but I can’t seem to locate bottle jacks under the factory Jack points (the width of the ramps don’t cooperate). Am hoping I can lift the car from a center point (or use a 2x4 or something to span the lift points etc.
Agree, the front lift points are tricky. I've considered making a lift bar out of some box tubing that fits my bridge jack. Complicated by the idea that I'd like to not block belly pan access...
1984 M491 Coupe 2014 Cayman S |
Use a 2x4, square tubing, etc to bridge the front crossmember and then use a jack on it.
Since you are on a 4 post, I'd assume a small bottle jack in the tray. |
HF has a cheap lift bar that should work, I wouldn’t use it on a truck but fine for 911. $56 bucks
Rolling bridge jack is great but not cheap.
Spend the $250 to get the rolling jack designed for your lift. I bought two for mine. Now I can jack the entire car up and remove all tires.
please link to the ones you bought for $250. I'll buy them in a heartbeat.
I have a GregSmith 4 post and they are close to $1k
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Agreed, if I can get rolling jacks for $250 each I'm in. I saw someone used the QuickJack on their 4 post lift. Bendpak commented on it on their website basically saying that it looks hokey, but it should be stable. That was a couple of months ago and I see that link/post is no longer there.
That is likely the route I'll go. Not much less expensive than bridge jacks, but much more versatile. Here's the video the referenced: https://www.youtube.com/watch?v=B93tNL1V2R8 |
That’s interesting, thanks for posting. My 4 post has fairly wide track spacing, so I doubt the QJ would have a place to set, but I may have a look at this next time I get a chance.
I went with a rolling bridge jack. Expensive appx $700. I’d still like to see the ones for $250. |
Same here on the rolling jacks for 250. I’d be in for two
Vince '82 930 ROW coupe bbs motorsport wheels of various vintage/style |
OldSpool87 - $700 is a little easier to swallow. Can you link that one?
Here you go. I don’t know this merchant but you get the idea:
https://www.mobiledistributorsupply.com/chlrj35-challenger-rj35-3-500-lb-capacity-rolling-jack-challenger?gclid=EAIaIQobChMIqdjE0InK8AIVGKjICh0iE wjeEAQYASABEgJDwvD_BwE Sent from my iPhone using Tapatalk
1987 Marine Blue 930 1982 911SC White Plains, NY |
To support the front end after its in the air with a car hoist, position a doubled-up a 2x4 or 6, under the front torsion bar ends then support using two extended jack stands underneath..... or equivalent. Sherwood |
With one hand. It rolls between the lift runways. Once in place, you just move it back and forth. My lowered track car clears it.
