1989 930 3.2 engine run over after switch off
Recently the car develops the engine run over after switch off intermittently. Usually after after engine warm/a few miles drive. After searching the forum, I only found the thread with ignition delay relay on 930 Turbo which seems not related to my case.
It is the engine running roughly/jerky after the key switch off. Not the kind of delay to burn the fuel out as I search the forum. As I uploaded the clip; https://youtu.be/RsurPz2YcVw All the vacuum hoses checked with no leakage/breakage/lose. A good known key switch was replaced but still run over intermittently. Anywhere to start the diagnosis? Thank you. SmileWavy |
That seems like it's dieseling. ?? Could it be a bad/dirty injector letting fuel by for a moment?
what is your fuel mix set up C/O? with the oxy sensor disconnected and measuring in front of the catalyst?
Ivan |
Can you clarify as a 930 engine is a 3.3 did you put a 3.2 in it? 2 different fuel injection systems 1 cis the other efi
Any chance you have a solid-state DME relay (assuming you have Motronic / 3.2)?
New plugs (factory spec). All the vacuum hoses checked with no leaks. Throttle valve, idle air control valve, and air flow meter cleaned. Brand new DME relay underseat replaced. Thank you. |
| All times are GMT -8. The time now is 09:17 AM. |
