1977 911s hesitates and stalls when hot
Hi Guys
I just picked up a new 77 911s. I road tripped the car home from L.A. to Colorado . A few issues. Car hesitates when cold and hot 2-3k rpm Car when it warms up stalls sometimes when the clutch is engaged at a stand still . I have to keep it revved to keep the motor running. Any ideas.
1973 targa hot rod; 91 Miata. M coupe sold 1977 911s; E39 m5 |
Where to start?? But sounds like a fuel issue (lean).
You need to do a full check of the fuel system. Be prepared to spend a few weeks in there and hopefully not too many $s. Search a few threads - there are plenty - on diagnosing CIS issues. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Take it to someone that knows what they're doing. CIS can be a pain to diagnose even when you know how the system works. You'll need a pressure gauge and knowledge on how to read the pressures.
Well I took the car down to my mechanics. Eisenbud’s best in Denver . He spent 30 minutes with the car.
Changed the air fuel mixture Changed the timing Discovered a spark plug wire that was not snapped completely over the spark plug cap. I think I will keep leaving it to the experts.
Please let us know what else gets done and what the mechanic said.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Kach22i that was it...car runs perfect . Like a Porsche
When they are running right, all the world's problems just fade away.
