VacantSky's Avatar
930 clutch/release bearing install
Does this fork engagement look right guys? I can’t see how it’s wrong but I’ve read too many threads now of it not being installed correctly and am paranoid to be honest
Don’t really feel like dropping this again if I can avoid it (2.5 hours is my record now)
EDIT: I realize she looks a little bit dry in that pic and separated them real quick to put a film of moly grease on the tube and clutch fork
Old 05-23-2021, 11:29 AM
proporsche's Avatar
well you are correct ..looks dry the clutch tube as well as the fork contact....i usually use Sachs lubricant or Bosch-but Bosch is NLA....
Did you put any grease on the tube at all...inside the To bearing?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-23-2021, 12:23 PM
VacantSky's Avatar
Ivan
After posting that pic I separated the engine/trans and lubricated the tube and the fingers, and reassembled. But it looks correct? I’ve just hung the engine and trans again. I can’t see how else I could assemble it, but I’m being paranoid lol
Old 05-23-2021, 01:02 PM
You got it.
206 637 4071
Old 05-23-2021, 01:14 PM
VacantSky's Avatar
Thanks guys, pelican never fails!
Kenny
Old 05-23-2021, 01:19 PM
proporsche's Avatar
ya ,you are ok;-)
Ivan
Old 05-23-2021, 01:39 PM
