Roslin's Avatar
Electromotice TEC GT 200, injector wiring
Hello everyone,
Why can only two low impedance injectors be run per channel with Tec gt 200?
Seems my 1984 Carrera 3.2 injector wiring setup is wired with 3 injectors on each of the two channels.
Roslin
Porsche 911 SC 3.0
Old 05-23-2021, 10:47 AM
Dr J's Avatar
Based on what you posted, it says two HIGH impedance injectors, not LOW impedance. They are to be connected in parallel which will half the impedance, thus doubling the current. If you use low impedance you are increasing the current draw which is why they want high impedance injectors. They are clearly and reasonably concerned that you not exceed the current limit of the TEC unit. With 3 injectors, the current is triple that of one injector.
Since the last sentence I can see in your picture of the TeC manual speaks of sequential firing, I expect you have 6 injector outputs that you can wire one to each injector.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 05-23-2021, 11:59 AM
Roslin's Avatar
Yes of course , i meant high impedance. I just wanted to run the 6 injectors as they are wired original, for simplicity here in the beginning as the injector wiring is already there, but i may then change the wiring, to sequential or 3x2
I'm just at the very beginning, and trying to sort out how to wire the whole setup.
I'm altering my 3.0 SC to EFI with stock 3.2 intake system.
Porsche 911 SC 3.0
Old 05-23-2021, 01:18 PM
