Senior Member
Leland Pate's Avatar
Attn: 993 owners- Make your mufflers LPMM's today!
I've posted this on the Rennlist 993 board, but figured my fellow PP-heads would enjoy it too.
There are a bazillion muffler combos available to the 993 owner. But, most of them require the owner to part with the better part of $1,000 bucks or so.
Driven by shear cheapness and backed by years of frankenmuffler experience, I decided to pave into the unknown... I decided to create my own sport muffler.
It seemed there were a couple of options as far as how to modify the guts of the mufflers. In the end, I decided it was worth a try to create a by-pass pipe between the inlet and outlets. $7.50 in galvanized pipe from Ace Hardware and off I went.
All in all, I am very happy with the result. The car has that throaty growl that I have wanted so badly. At idle, you can just barely tell something is different. It burbles and has a more pronounced throatiness to it. When you get on the gas it really comes alive. Not in a drastic way; I don't think it is anywhere near as loud as supercups, but man it sounds good.
This was very easy to do. I bought two feet of 1 1/2" pipe, eyeballed it and started cutting the ends to match the inlet and outlet pipes. This was the most tedious part as it was a lot of trial and error before I got an acceptable fit. Once that was done I marked the pipes and cut the holes. Then the bypass pipe was welded together and painted with silver hi-temp to try and protect the weld (I ain't no fancy stainless Tig welder, just yet). Speaking of welds, you all can make fun of my poor beads, but I couldn't care less. I didn't do this for the bling factor and I know my skills lack finesse. Only other thing that had to be modified was the heat shield. You can see I made a cutout for it to fit around the new bypass pipe.
This would have been much easier if I had the proper tools (plasma cutter). As it was, I had to slowly use my cutoff tool with an air compressor that can hardly keep up. But I managed.
Not pretty, but this was just a beta.
A short video of my mufflers can be seen here:
http://manmicro.com/porsche/muffler/new_mufflers.MOV
Clive, another Rennlister, 993 owner and LPMM backer had a local weld shop fab up some better SS bypass pipes and he used 2" tubing instead of the 1.5" I used.
Clive put together a LPMM movie and can be seen here... I star in it... well, sorta...
http://www.manmicro.com/porsche/muffler/bypass.wmv
Anyway, this is a great modification and every 993 owner deserves a pair.
Are these great cars or what?!
Chief Architect and Mastermind,
SCWDP
Old 08-03-2005, 11:06 PM
Senior Member
Have I been banned or something? Why aren't pics loading tonight?
SCWDP
Old 08-03-2005, 11:09 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
hmmm if I only had mufflers. ;o)
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 08-04-2005, 12:54 AM
MIK911's Avatar
Strong work!
Is this mod similar to the RSR muffler (robin sun's)) in structure and/or sound? How's it sound compared to factory 'motor sound pkg'?
Post a sound cip!!
mike
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 08-04-2005, 04:40 AM
Metal Guru
911nut's Avatar
Lee, haven't the SCWDP bounty hunters caught up with you yet? There's a contract out on you for defecting .
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 08-04-2005, 04:59 AM
Senior Member
Mike, there are two sound/video clips in the post above.
I'm going to try uploading a photo again.
From what I understand, the motorsound mufflers use a 3/4" internal bypass pipe instead of the 1/2" pipe found in standard mufflers. We are installing 1.5" and 2" external bypass pipes in conjunction with the internal pipes.
Let's try another photo...
SCWDP
Old 08-04-2005, 11:01 AM
Senior Member
Well, now I know why we keep Techweenie around... man, how did you know to change the script to upload5???
SCWDP
Old 08-04-2005, 11:04 AM
air cooled - H20 cooled
LPMM muffler mod back in the day ...
Herr Leland Pate -
A big-ole Danke Schoen for being the DIY muffler modification "mastermind" LPMM. .. It was back in the days of Porschelist... IIRC it was Viken who suggested I try your DIY, the LPMM. .. It's a great owner DIY.
- Cheers,
'98 Carrera S
Ordered new -
Old 05-23-2021, 07:30 PM
