Passenger seat rail stopper
Hi everyone,
I am in need of a help/guidance. My passenger seat is not sliding all the way backwards. Cannot reach to the front bolts. It slides forward ok. Is there a stopper somewhere that i can adjust? I checked the lever and latch is fully disengaging so i know it is not that, i also cannot see any obstacles "visually" when i look at the rail and the passage. Any tips, tricks or guidance is highly appreciated Thanks, Z |
abides.
Have you tried sliding it with the rear pair of bolts removed?
Graham 1984 Carrera Targa |
yes last night i removed all 4 bolts from the rear and still stops at the same place.
You didn’t specify the year of your car or seats. Some years of Recaro seats had a safety feature to prevent the seats sliding too far in an accident. This safety device is riveted to the seat rail and the rivet can fail over time causing the device to engage which will halt the seat from sliding far enough to allow access to the seat bolts. A few threads on here about the issue as well as possible solutions.
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
This post shows the safety pin in the seat rails
https://forums.pelicanparts.com/porsche-911-technical-forum/1065818-project-pepita-i-attempt-refurbishing-early-comfort-seats.html#post10926490
Thanks for the input, let me check about the safety pin Last edited by gassian; 05-25-2021 at 06:55 PM.. |
quick update..
after looking through both rails once again, i saw this metal/rock piece on one of the rails and i pushed it and wiggled it using flat screw driver and seat started sliding further back I will see how long this will keep working but i shall see Thank you all |
